- To: "" <>
- Subject: [cgal-discuss] Unable to fix the problem:
- Date: Sun, 11 Dec 2016 13:07:59 +0000 (UTC)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:moqJpBfUU7Quetc4WynXL4vIlGMj4u6mDksu8pMizoh2WeGdxc69Zh7h7PlgxGXEQZ/co6odzbGH6Oa+ASdavd7B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx/68yez615TPbk1Bgj24aLdjZFXs9ESC/vUR1MFpJa81jxfIuXBVYP9+xGVyJFvVkQy2rpO785dntihRoPk87NVoUKPgfq1+Q6YOXw4rK2Qk2Mq+nhnKSAKJrkAdVGoW2iRFGQ3MpEXxRYmv63PSp+N93y7cNsrzG+MaQzOnuoxrQRrhjm88Njg28Cnph9Z1heoPqwm/+UUn65/dYIaScvF5e/WOLpshWWNdU5MJBGR6CYSmYt5VVuc=
Hello,
I have been trying hard to fix the following compilation error, but so far no clue.
/home/csverma/Disk/Software/CompGeom/CGAL/V4.9/include/CGAL/Polygon_mesh_processing/internal/named_params_helper.h:40:20: error: expected nested-name-specifier before ‘property_map_value’
typedef typename property_map_value<PolygonMesh,
/home/csverma/Disk/Software/CompGeom/CGAL/V4.9/include/CGAL/Polygon_mesh_processing/internal/named_params_helper.h:40:20: error: expected ‘;’ at end of member declaration
/home/csverma/Disk/Software/CompGeom/CGAL/V4.9/include/CGAL/Polygon_mesh_processing/internal/named_params_helper.h:40:38: error: expected unqualified-id before ‘<’ token
/home/csverma/Disk/Software/CompGeom/CGAL/V4.9/include/CGAL/Polygon_mesh_processing/internal/named_params_helper.h:44:40: error: ‘Point’ was not declared in this scope
typedef typename CGAL::Kernel_traits<Point>::Kernel Kernel;
/home/csverma/Disk/Software/CompGeom/CGAL/V4.9/include/CGAL/Polygon_mesh_processing/internal/named_params_helper.h:44:45: error: template argument 1 is invalid
csv
- [cgal-discuss] Unable to fix the problem:, Chaman Singh Verma, 12/11/2016
- Re: [cgal-discuss] Unable to fix the problem:, Andreas Fabri, 12/11/2016
- Re: [cgal-discuss] Unable to fix the problem:, Chaman Singh Verma, 12/11/2016
- Re: [cgal-discuss] Unable to fix the problem:, Laurent Rineau (CGAL/GeometryFactory), 12/27/2016
