- To:
- Subject: Re: [cgal-discuss] Unable to fix the problem:
- Date: Tue, 27 Dec 2016 11:29:12 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:V4W5OxICYQ4HJdJG4tmcpTZWNBhigK39O0sv0rFitYgUKvnxwZ3uMQTl6Ol3ixeRBMOAuqkC2rGd6vyoGTRZp83e4DZaKN0EfiRGoPtVtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdaymUrLV2s+43uT395zIaBhTnxK8Z6lzJVO4t1b/rM4T1MFGI7srxx3V6kFJfelf2CsoDn26u1HT68C18YJ54gpZsO4m7d8BG+2ue60lV7FeEHI8MmY47dDDvhbKSU2I/HRKATZeqQZBHwWQtEKyZZz2qCav7uc=
Le Sunday, December 11, 2016 1:07:59 PM CET Chaman Singh Verma a écrit :
> Hello,
> I have been trying hard to fix the following compilation error, but so far
> no clue.
> /home/csverma/Disk/Software/CompGeom/CGAL/V4.9/include/CGAL/Polygon_mesh_pr
> ocessing/internal/named_params_helper.h:40:20: error: expected
> nested-name-specifier before ‘property_map_value’ typedef typename
> property_map_value<PolygonMesh,
> ^/home/csverma/Disk/Software/CompGeom/CGAL/V4.9/include/CGAL/Polygon_mesh_
> processing/internal/named_params_helper.h:40:20: error: expected ‘;’ at end
> of member
> declaration/home/csverma/Disk/Software/CompGeom/CGAL/V4.9/include/CGAL/Pol
> ygon_mesh_processing/internal/named_params_helper.h:40:38: error: expected
> unqualified-id before ‘<’ token typedef typename
> processing/internal/named_params_helper.h:44:40: error: ‘Point’ was not
> declared in this scope typedef typename
> CGAL::Kernel_traits<Point>::Kernel Kernel;
> processing/internal/named_params_helper.h:44:45: error: template argument 1
> is invalid typedef typename CGAL::Kernel_traits<Point>::Kernel Kernel;
> csv
Hi, from the information you gave us, there is no way we can understand what
happened. We would need a way to reproduce it. The general information about
bug reporting is here: http://www.cgal.org/bug_report.html
At the very least we need to know:
- which operating system (Windows, Linux...?) and which version,
- which compiler (g++, clang, cl.exe...?) and which version,
- what code you were trying to compile.
Laurent Rineau, PhD
- [cgal-discuss] Unable to fix the problem:, Chaman Singh Verma, 12/11/2016
- Re: [cgal-discuss] Unable to fix the problem:, Andreas Fabri, 12/11/2016
- Re: [cgal-discuss] Unable to fix the problem:, Chaman Singh Verma, 12/11/2016
- Re: [cgal-discuss] Unable to fix the problem:, Laurent Rineau (CGAL/GeometryFactory), 12/27/2016
