- To:
- Subject: Re: [cgal-discuss] non-empty sphere exception
- Date: Tue, 27 Dec 2016 11:12:14 -0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:R113LBRngpeM8RTZ7MOOY4h6sdpsv+yvbD5Q0YIujvd0So/mwa64ZxeN2/xhgRfzUJnB7Loc0qyN4vymATRLuM7Y+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiP/YbOaVBImCaleuE1aw6nqB3Y8MgQm4prbKgrjQDYp2NBPOVQy2QvLl2am1Pw59y74YV4oBhX7vku/soFXaThdLkjVpRZCi4nOiY7/p7Frx7GGCKD735UfWgKmRpFBwyNuBj2V5K3vSbmvepw3C2yMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
> On Dec 27, 2016, at 1:35 AM, Sebastien Loriot (GeometryFactory)
> wrote:
> The Delaunay triangulation of a set of points is uniquely defined (if
> your points are in general position), so if you do a flip, you will
> break the Delaunay property.
Thanks for your answer, Sebastien!
Just confirming that this exception (which only occurs during debug mode) is
the result.
Otherwise, I have some other problem to look at.
Adam Getchell
https://keybase.io/adamgetchell
> Sebastien.
> On 12/27/2016 10:23 AM, Adam Getchell wrote:
>> Hello,
>> I’m hitting the CGAL_triangulation_assertion(false) on line 1985 of
>> Delaunay_triangulation_3.h when I’m in debug mode, but not release mode.
>> This is after I perform a flip(), which as I understand invalidates the
>> Delaunay Triangulation, but not the underlying triangulation data
>> structure.
>> Does this refer to the Delaunay triangulation being invalid via the
>> empty sphere property in 3D, or something else?
>> https://twitter.com/adamgetchell/status/813676373415890944
>> Adam Getchell
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] non-empty sphere exception, Adam Getchell, 12/27/2016
- Re: [cgal-discuss] non-empty sphere exception, Sebastien Loriot (GeometryFactory), 12/27/2016
- Re: [cgal-discuss] non-empty sphere exception, Adam Getchell, 12/27/2016
