- To:
- Subject: [cgal-discuss] Inconsistent nef polyhedron topological properties
- Date: Tue, 24 Jan 2017 19:28:39 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:kdIovhFycxFxQqSjQvpGxZ1GYnF86YWxBRYc798ds5kLTJ76rs2wAkXT6L1XgUPTWs2DsrQf2raQ7vmrADZdqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2a3IyL0LW59JTXJglJnzGgeqhaLROsrAyXuNNFr5FlL/MXyxDJpX9BYKxzzHlpIhqslgzw5s629dY39i1KuvVn6MdaXaXzea0QQrlRDTBgOGcwsp64/SLfRBeCsyNPGl4dlQBFVlDI
Hello,
I am creating a cube as a nef polyhedron by defining it as the intersections of the negative sides of the 6 bounding planes, based on the following example:
It then checks the properties, saves the cube to a nef3 file, loads it again, and checks the property again
I would expect that the cube has the following properties.
- 2-manifold (is_simple() == true)
- The number of volumes = 2 (inside and outside the cube)
- The number of shells = 2 (the inside and outside boundaries)
- The number of facets = 6
- The number of half-facets = 12
- The number of edges = 12
- The number of half-edges = 24
- The number of vertices = 8
My code prints the followings.
CreateACube()
nefCube.is_simple() == true
nefCube.number_of_volumes(), expected 2, result = 3
GetNumberOfShells(nefCube), expected 2, result = 4
nefCube.number_of_facets(), expected 6, result = 12
nefCube.number_of_halffacets(), expected 12, result = 24
nefCube.number_of_edges(), expected 12, result = 24
nefCube.number_of_halfedges(), expected 24, result = 48
nefCube.number_of_vertices(), expected 8, result = 16
LoadACube()
I did not get many of the expected properties.
However, the nef3 file does state:
vertices 8
halfedges 24
facets 12
volumes 2
shalfedges 48
shalfloops 0
sfaces 16
and when I cross-checked the result by loading the nef3 file to the polyhedron_3 demo (http://www.cgal.org/demo/4.9/polyhedron_3.zip), it correctly prints the followings.
Test_ByEquation (mode: flat+edges, color: #6464ff)
Nef_3 polyhedronNumber of vertices: 8
Number of edges: 12
Number of facets: 6
number of volumes: 2Bounding box: min (0,0,0), max (2,2,2)
File: <path omitted>/CGAL/output/Test_ByEquation.nef3
The minimum working code and the resulting nef3 file are attached. Could anyone please point out my mistakes? Thank you.
Best regards,
Nicholas Mario Wardhana
Description: Binary data
#include <CGAL/Exact_integer.h> #include <CGAL/Extended_homogeneous.h> #include <CGAL/Nef_polyhedron_3.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/IO/Nef_polyhedron_iostream_3.h> #include <fstream> #include <iostream> typedef CGAL::Extended_homogeneous<int> Kernel; typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron; typedef Nef_polyhedron::Plane_3 Plane_3; typedef Nef_polyhedron::Point_3 Point_3; typedef Nef_polyhedron::Volume_const_iterator Volume_const_iterator; typedef Nef_polyhedron::Shell_entry_const_iterator Shell_entry_const_iterator; Nef_polyhedron MakeCubeByPlaneEquation(const Point_3& minPoint, const Point_3& maxPoint) { Nef_polyhedron N0(Plane_3(1, 0, 0, -CGAL::to_double(maxPoint.x()))); Nef_polyhedron N1(Plane_3(-1, 0, 0, CGAL::to_double(minPoint.x()))); Nef_polyhedron N2(Plane_3(0, 1, 0, -CGAL::to_double(maxPoint.y()))); Nef_polyhedron N3(Plane_3(0, -1, 0, CGAL::to_double(minPoint.y()))); Nef_polyhedron N4(Plane_3(0, 0, 1, -CGAL::to_double(maxPoint.z()))); Nef_polyhedron N5(Plane_3(0, 0, -1, CGAL::to_double(minPoint.z()))); Nef_polyhedron nefCube = N0*N1*N2*N3*N4*N5; return nefCube; } int GetNumberOfShells(const Nef_polyhedron& nefPolyhedron) { int numberOfShells = 0; Volume_const_iterator c; CGAL_forall_volumes(c, nefPolyhedron) { int is = 0; Shell_entry_const_iterator it; CGAL_forall_shells_of(it, c) { ++numberOfShells; } } return numberOfShells; } void PrintTopologicalProperties(const Nef_polyhedron& nefCube) { if(nefCube.is_simple()) std::cout << "nefCube.is_simple() == true" << std::endl; else std::cout << "nefCube.is_simple() == false" << std::endl; std::cout << "nefCube.number_of_volumes(), expected 2, result = " << nefCube.number_of_volumes() << std::endl; std::cout << "GetNumberOfShells(nefCube), expected 2, result = " << GetNumberOfShells(nefCube) << std::endl; std::cout << "nefCube.number_of_facets(), expected 6, result = " << nefCube.number_of_facets() << std::endl; std::cout << "nefCube.number_of_halffacets(), expected 12, result = " << nefCube.number_of_halffacets() << std::endl; std::cout << "nefCube.number_of_edges(), expected 12, result = " << nefCube.number_of_edges() << std::endl; std::cout << "nefCube.number_of_halfedges(), expected 24, result = " << nefCube.number_of_halfedges() << std::endl; std::cout << "nefCube.number_of_vertices(), expected 8, result = " << nefCube.number_of_vertices() << std::endl; } void CreateACube() { Nef_polyhedron nefCube = MakeCubeByPlaneEquation(Point_3(0, 0, 0), Point_3(2, 2, 2)); std::cout << "CreateACube()" << std::endl; PrintTopologicalProperties(nefCube); std::ofstream out("CGAL//output//Test_ByEquation.nef3"); out << nefCube; std::cout << std::endl; } void LoadACube() { Nef_polyhedron nefCube; std::ifstream in("CGAL//output//Test_ByEquation.nef3"); in >> nefCube; std::cout << "LoadACube()" << std::endl; PrintTopologicalProperties(nefCube); } int main(int argc, char **argv) { CreateACube(); LoadACube(); return 0; }
- [cgal-discuss] Inconsistent nef polyhedron topological properties, Nicholas Mario Wardhana, 01/24/2017
- Re: [cgal-discuss] Inconsistent nef polyhedron topological properties, Sebastien Loriot (GeometryFactory), 01/30/2017
- Re: [cgal-discuss] Inconsistent nef polyhedron topological properties, Nicholas Mario Wardhana, 01/30/2017
