cgal-discuss - Re: [cgal-discuss] Inconsistent nef polyhedron topological properties
  • To:
  • Subject: Re: [cgal-discuss] Inconsistent nef polyhedron topological properties
  • Date: Mon, 30 Jan 2017 14:01:57 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:to073RGZ0OxABIKqDlH94J1GYnF86YWxBRYc798ds5kLTJ75os6wAkXT6L1XgUPTWs2DsrQf2raQ7furBTBIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/mxzP24rp3Pfx1T1n36eqJ3NBzwrAPLt8BQj5ElMbc00hKOo31GfKNdympsYF6ShB3h/dzjwJk2+CtZv7ct9tVLTL7hV6U+V71RSjo8YE4v48i+/yLORwKU+noRVC0ylQBJBBSNrD73WZL8rjHrmON2xC6ALIy8BeQvXTO47qB3DhrsoCgCPj89tmrQj5oj3+pgvBu9qkknkMbva4aPOa8mcw==
On 01/30/2017 12:40 PM, Nicholas Mario Wardhana wrote:
Dear Sebastien,
Thank you for your reply.
Regarding the number of volumes, am I correct to say that the number
three comes from the volumes inside my cube, the one between my cube and
infimaximal cube, and the one outside the infimaximal cube?
Yes, exactly.
Sebastien.
Best regards,
Nicholas
On 30 January 2017 at 05:16, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
The difference you observe comes from the infimaximal box [1].
This means that you have another cube around your cube, which explains
why all numbers but #volumes are doubled.
Sebastien.
[1] http://doc.cgal.org/latest/Nef_3/index.html#title2
<http://doc.cgal.org/latest/Nef_3/index.html#title2>
On 01/24/2017 08:28 PM, Nicholas Mario Wardhana wrote:
Hello,
I am creating a cube as a nef polyhedron by defining it as the
intersections of the negative sides of the 6 bounding planes,
based on
the following example:
http://doc.cgal.org/latest/Nef_3/index.html#title6
<http://doc.cgal.org/latest/Nef_3/index.html#title6>
It then checks the properties, saves the cube to a nef3 file,
loads it
again, and checks the property again
I would expect that the cube has the following properties.
* 2-manifold (is_simple() == true)
* The number of volumes = 2 (inside and outside the cube)
* The number of shells = 2 (the inside and outside boundaries)
* The number of facets = 6
* The number of half-facets = 12
* The number of edges = 12
* The number of half-edges = 24
* The number of vertices = 8
My code prints the followings.
CreateACube()
nefCube.is_simple() == true
nefCube.number_of_volumes(), expected 2, result = 3
GetNumberOfShells(nefCube), expected 2, result = 4
nefCube.number_of_facets(), expected 6, result = 12
nefCube.number_of_halffacets(), expected 12, result = 24
nefCube.number_of_edges(), expected 12, result = 24
nefCube.number_of_halfedges(), expected 24, result = 48
nefCube.number_of_vertices(), expected 8, result = 16
LoadACube()
I did not get many of the expected properties.
However, the nef3 file does state:
vertices 8
halfedges 24
facets 12
volumes 2
shalfedges 48
shalfloops 0
sfaces 16
and when I cross-checked the result by loading the nef3 file to the
polyhedron_3 demo (http://www.cgal.org/demo/4.9/polyhedron_3.zip
<http://www.cgal.org/demo/4.9/polyhedron_3.zip>), it
correctly prints the followings.
Test_ByEquation (mode: flat+edges, color: #6464ff)
Nef_3 polyhedron
Number of vertices: 8
Number of edges: 12
Number of facets: 6
number of volumes: 2
Bounding box: min (0,0,0), max (2,2,2)
File:<path omitted>/CGAL/output/Test_ByEquation.nef3
The minimum working code and the resulting nef3 file are
attached. Could
anyone please point out my mistakes? Thank you.
Best regards,
<https://sympa.inria.fr/sympa/info/cgal-discuss>
