- To:
- Subject: Re: [cgal-discuss] CGAL instalation Linux cmake problem
- Date: Thu, 9 Feb 2017 16:40:13 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:9ODeHhCFacseJ4JCz5DIUyQJP3N1i/DPJgcQr6AfoPdwSP74p8bcNUDSrc9gkEXOFd2CrakV16yG7uu9AyRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUt2assKsyurn+4HPex4aw32mcLZqJVO3qx/Qv48Ym8x5O6Mpw1zIpHVPPO9ZzGctKVOIlAvn/ZSM+8to/C1U/v4g7MVdSr7SfqIiTLUeAi51HXoy4ZjKq5DFegyT62EbGjEXjBNOBBTI9hbnQJb+tQP1s+N83G+ROsigHuN8Yiir86o+EEygsywALTNsqGw=
Hi Laurent!
Could you recomend any post link about cgal and about how to calculate intersection of 3 planes.
In my case I have normal vector of plane and centroide.
I need to know the know how of cgal to calculate this point
I know mathematics to calculate it but I would like to get this point with cgal.
Thanks and best regards
2017-02-08 10:44 GMT+01:00 Laurent Rineau (CGAL/GeometryFactory) <>:
Le Tuesday, February 7, 2017 7:27:08 PM CET Ivan Io a écrit :
> full output <https://paste.debian.net/hidden/d39d567e/>
> -- Configuring examples in examples/BGL_OpenMesh
> -- Requested component: MPFR
> -- Requested component: GMP
> -- Boost version: 1.62.0
> -- Examples that use OpenMesh will not be compiled.
> What does this output mean? and what I need to do to compile examples?
Hi,
Some of the examples in the BGL package shows that CGAL algorithms can be
used on OpenMesh data structures. If your system does not have OpenMesh, of
course those examples cannot be compiled. But that is no big deal: all the
other examples that do not use OpenMesh are configured and can be compiled.
> P.S. is it suitable place for such help requests?
Yes, that is the right place.
Let's hope I gave you a satisfying answer, and you will go on and continue
using CGAL.
Laurent Rineau, PhD
Iván Otero González
Skype: ivanoterouvigo
Tlf. Lab. 222: 813499
Tlf. Lab. 218: 813998
Research Line : ARCHITECTURE AND BUILDING
GeoTech
Applied Geotechnologies Research Group | Geotech
Universidade de Vigo
E.E. Minas
36310 Vigo (Spain)
- [cgal-discuss] CGAL instalation Linux cmake problem, Ivan Io, 02/07/2017
- Re: [cgal-discuss] CGAL instalation Linux cmake problem, Laurent Rineau (CGAL/GeometryFactory), 02/08/2017
- Re: [cgal-discuss] CGAL instalation Linux cmake problem, Iván otero, 02/09/2017
- Re: [cgal-discuss] CGAL instalation Linux cmake problem, Laurent Rineau (CGAL/GeometryFactory), 02/10/2017
