cgal-discuss - Re: [cgal-discuss] CGAL instalation Linux cmake problem
  • To:
  • Subject: Re: [cgal-discuss] CGAL instalation Linux cmake problem
  • Date: Fri, 10 Feb 2017 16:08:50 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:Sj3XeBIaGXDio/pdD9mcpTZWNBhigK39O0sv0rFitYgUKvnxwZ3uMQTl6Ol3ixeRBMOAuq4C27Wd7fGoGTRZp83e4DZaKN0EfiRGoPtVtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdaymUrLV2s+43uT395zIaBhTnxK8Z6lzJVO4t1b/rM4T1MFGI7srxx3V6kFJfelf2CsoDn26u1HT68C18YJ54gpZsO4m7d8BG+2ue60lV7FeEHI8MmY47dDDvhbKSU2I/HRKATZeqQZBHwWQtEKyZZz2qCav7uc=
Le Thursday, February 9, 2017 4:40:13 PM CET Iván otero a écrit :
> Hi Laurent!
> Could you recomend any post link about cgal and about how to calculate
> intersection of 3 planes.
> In my case I have normal vector of plane and centroide.
> I need to know the know how of cgal to calculate this point
> I know mathematics to calculate it but I would like to get this point with
> cgal.
There is a constructor of a `CGAL::Plane_3<K>` from a point and a vector:
http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Plane__3.html
Plane_3 (const Point_3< Kernel > &p, const Vector_3< Kernel > &v)
introduces a plane h that passes through point p and that is
orthogonal
to v.
And then you will have to use the intersection function:
http://doc.cgal.org/latest/Kernel_23/group__intersection__linear__grp.html
The intersection of the two first `Plane_3<K>` will gives you a `Line_3<K>`,
unless the plans are parallel. Then the intersection of the resulting
`Line_3<K>` with the third `Plane_3<K>` should give you a `Point_3<K>`,
unless the line is parallel to the plane.
Laurent Rineau, PhD
