- To:
- Subject: Re: [cgal-discuss] Error when compiling with LEDA
- Date: Fri, 24 Feb 2017 14:22:11 +0100 (CET)
On Fri, 24 Feb 2017, Iordan Iordanov wrote:
Hi Sebastien,
I am actually using ccmake for the configuration step, but this is
what I do, yes. I had not tried disabling GMP; I did it now, but there
is no difference in the output, it still fails.
It will perhaps be useful to give you the trace for the first error:
Scanning dependencies of target CGALmake
[ 4%] Building CXX object
Installation/src/CGAL/CMakeFiles/CGAL.dir/all_files.cpp.o
In file included from
/Users/iordanov/Documents/Code/builds/cgal-leda/Installation/src/CGAL/all_files.cpp:1:
/Users/iordanov/Documents/Code/cgal-INRIA/Geomview/src/CGAL/Geomview_stream.cpp:27:
/Users/iordanov/Documents/Code/cgal-INRIA/Geomview/include/CGAL/IO/Geomview_stream.h:28:
/Users/iordanov/Documents/Code/cgal-INRIA/Kernel_23/include/CGAL/basic.h:29:
/Users/iordanov/Documents/Code/cgal-INRIA/Installation/include/CGAL/config.h:251:4:
error: "This compiler does not have a working STL"
# error "This compiler does not have a working STL"
Is it possible that the error has to do with Geomview? Or is it
even deeper, in the Kernel_23?
The error is long before that. If you look at the cmake output, you may notice that all "Performing Test CGAL_CFG_*" failed. You need to find out why they are failing (cmake probably leaves a log somewhere, or has some verbose option or something).
Marc Glisse
- [cgal-discuss] Error when compiling with LEDA, Iordan Iordanov, 02/24/2017
- Re: [cgal-discuss] Error when compiling with LEDA, Sebastien Loriot (GeometryFactory), 02/24/2017
- Re: [cgal-discuss] Error when compiling with LEDA, Iordan Iordanov, 02/24/2017
- Re: [cgal-discuss] Error when compiling with LEDA, Marc Glisse, 02/24/2017
- Re: [cgal-discuss] Error when compiling with LEDA, Iordan Iordanov, 02/27/2017
