cgal-discuss - Re: [cgal-discuss] Error when compiling with LEDA
  • To:
  • Subject: Re: [cgal-discuss] Error when compiling with LEDA
  • Date: Fri, 24 Feb 2017 15:00:22 +0100 (CET)
Hello Marc,
Thank you for the comment!
Indeed, I got into the log file and there was an error about X11,
it couldn't find the library. I provided the path and I was able
to compile CGAL.
Best,
- Iordan
----- Original Message -----
> From: "Marc Glisse"
> To:
> Sent: Friday, 24 February, 2017 2:22:11 PM
> On Fri, 24 Feb 2017, Iordan Iordanov wrote:
> > Hi Sebastien,
> > I am actually using ccmake for the configuration step, but this is
> > what I do, yes. I had not tried disabling GMP; I did it now, but there
> > is no difference in the output, it still fails.
> > It will perhaps be useful to give you the trace for the first error:
> >>> make
> > Scanning dependencies of target CGAL
> > [ 4%] Building CXX object
> > Installation/src/CGAL/CMakeFiles/CGAL.dir/all_files.cpp.o
> > In file included from
> > /Users/iordanov/Documents/Code/builds/cgal-leda/Installation/src/CGAL/all_files.cpp:1:
> > /Users/iordanov/Documents/Code/cgal-INRIA/Geomview/src/CGAL/Geomview_stream.cpp:27:
> > /Users/iordanov/Documents/Code/cgal-INRIA/Geomview/include/CGAL/IO/Geomview_stream.h:28:
> > /Users/iordanov/Documents/Code/cgal-INRIA/Kernel_23/include/CGAL/basic.h:29:
> > /Users/iordanov/Documents/Code/cgal-INRIA/Installation/include/CGAL/config.h:251:4:
> > error: "This compiler does not have a working STL"
> > # error "This compiler does not have a working STL"
> > Is it possible that the error has to do with Geomview? Or is it
> > even deeper, in the Kernel_23?
> The error is long before that. If you look at the cmake output, you may
> notice that all "Performing Test CGAL_CFG_*" failed. You need to find out
> why they are failing (cmake probably leaves a log somewhere, or has some
> verbose option or something).
> Marc Glisse
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
