- To:
- Subject: Re: [cgal-discuss] Error when compiling with LEDA
- Date: Wed, 1 Mar 2017 09:33:10 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Which version of LEDA are you using?
Sebastien.
On 02/27/2017 11:20 AM, Iordan Iordanov wrote:
Hello all,
I have another problem related to this thread. Since last sime,
I was able to compile CGAL with LEDA, however I am unable to
compile any simple program using LEDA from CGAL. I tried to
investigate, but without positive results.
Please find attached to this message the output produced by make.
I should mention that initially I thought that I was using LEDA
incorrectly. I tried to compile the test leda_real in the package
Number_types, and I get the _same_ errors. In fact, I get the same
errors for any LEDA-related tests.
On the other hand, I tried compiling the tests/examples shipped
with LEDA itself, and it works just fine.
I have installed LEDA in the system folders, so I want to believe
there is no doubt that it is being detected, cmake confirms this.
Thank you,
- Re: [cgal-discuss] Error when compiling with LEDA, Sebastien Loriot (GeometryFactory), 03/01/2017
- Re: [cgal-discuss] Error when compiling with LEDA, Iordan Iordanov, 03/01/2017
