- To:
- Subject: Re: [cgal-discuss] Error when compiling with LEDA
- Date: Wed, 1 Mar 2017 09:40:52 +0100 (CET)
Hello Sebastien,
I am using version 6.4 for MacOS, downloaded very recently from the
website. I tried asking for a previous version, but it's not possible
to have it...
- Iordan
----- Original Message -----
> From: "Sebastien Loriot (GeometryFactory)"
> To:
> Sent: Wednesday, 1 March, 2017 9:33:10 AM
> Which version of LEDA are you using?
> Sebastien.
> On 02/27/2017 11:20 AM, Iordan Iordanov wrote:
> > Hello all,
> > I have another problem related to this thread. Since last sime,
> > I was able to compile CGAL with LEDA, however I am unable to
> > compile any simple program using LEDA from CGAL. I tried to
> > investigate, but without positive results.
> > Please find attached to this message the output produced by make.
> > I should mention that initially I thought that I was using LEDA
> > incorrectly. I tried to compile the test leda_real in the package
> > Number_types, and I get the _same_ errors. In fact, I get the same
> > errors for any LEDA-related tests.
> > On the other hand, I tried compiling the tests/examples shipped
> > with LEDA itself, and it works just fine.
> > I have installed LEDA in the system folders, so I want to believe
> > there is no doubt that it is being detected, cmake confirms this.
> > Thank you,
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- Re: [cgal-discuss] Error when compiling with LEDA, Sebastien Loriot (GeometryFactory), 03/01/2017
- Re: [cgal-discuss] Error when compiling with LEDA, Iordan Iordanov, 03/01/2017
