cgal-discuss - Re: [cgal-discuss] Compute angle between two vectors
  • To:
  • Subject: Re: [cgal-discuss] Compute angle between two vectors
  • Date: Fri, 03 Mar 2017 12:50:03 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:Ko0kxRTB65cjSyaDa2zfGLPQUNpsv+yvbD5Q0YIujvd0So/mwa64ZBGN2/xhgRfzUJnB7Loc0qyN4v2mAjBLus7J8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3Izkn9y1rpbcagENiDumaq5pNz23qx/Qv48Ym9hMMKE0n1Htq2ZSduJKjVlpI1+agl68zeiZ2NlM/iNVtu475uBJWrn9ZbV5B/QMCD07KW0z+IvxtB/ORBan7XQVViMRiBUeUFuN1w3zQpqk6niyjeF6wiTPZcA=
Le Friday, March 3, 2017 11:30:48 AM CET Thomas Holzmann a écrit :
> Hi,
> I'm using the epek kernel (without sqrt).
> I'm having two Vector_3 and want to compute the angle between them.
> I would usually compute the dot product between the normalized vectors,
> but I cannot compute the normalized vectors without sqrt.
> Is there also an (exact) way to compute the angle between the two
> vectors in CGAL?
There is no way to compute exact angles. As far as I know, the acos, asin,
atan, atan2 trigonometric functions are always using floating point numbers.
Even if you only want to compute the cosine or the sinus of the angle, then
you need the exact sqrt function.
However, if you only want to compare two angles, or compare an angle with a
constant (actually it will compare cosines and sinuses), then you can do it
exactly without sqrt.
Laurent Rineau, PhD
