cgal-discuss - Re: [cgal-discuss] Arrangement observer and notification order
  • To:
  • Subject: Re: [cgal-discuss] Arrangement observer and notification order
  • Date: Mon, 6 Mar 2017 09:03:46 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:oNxR/Rb+wJ55MzQQPBCMLNP/LSx+4OfEezUN459isYplN5qZpcu8bnLW6fgltlLVR4KTs6sC0LuL9fuxEjJcqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2a3IyK0fuv8cjTfxlQn2j6JqhjKQ2/6wTXrMgfx4V4bb0gzwPA5XpOdeMRzmxhIRefng33+9yrr6Nl6Dla7vI969ZbA+K9ZLU9VbUeDTI8Mmlz6tesrgjGVQLI530SVSIdnRNMRgTE9xrnRYyijiyvveV03GyWPNb9UKsvcTWk9aZiDhHy2wkdMDts3W/WwuJ3g69f6EasqR1xxIHZZKmaMfN/euXWetZMFjkJZdpYSyEUWtD0VIAIFedUZes=
Sure, go ahead.
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
On 6 March 2017 at 00:37, Ch'Gans <> wrote:
On 5 March 2017 at 00:02, Efi Fogel <> wrote:
> I think that you are correct on both counts.
> It should be symmetric and I'd pick the first order.
> We will fix it.
Should I create a bug report for this?
>    ____  _        ____             _
>                          _/
> On 2 March 2017 at 06:56, Ch'Gans <> wrote:
>> When inserting a (isolated) segment:
>> - Before create vertex
>> - After create vertex
>> - Before create Edge
>> - After create edge
>> When removing a (isolated) segment:
>> - Before remove edge
>> - Before remove vertex
>> - After remove vertex
>> - After remove edge
>> As you can see inserting and removing edges lead to a non symetrical
>> notification ordering, which I think is a bug.
>> I think that the notification ordering when inserting the edge is
>> correct, you start by inserting the first vertex, then the second, and
>> finally you *can* insert the edge since the 2 vertices are "fully"
>> inserted.
>> And so, the notification ordering when removing an edge is bogus, the
>> notifications should be: remove the edge, then remove a vertex (since
>> it is not used by any edge), then remove the other vertex.
>> I'm using the observer to maintain a (Qt) tree model of edges,
>> vertices and faces.
>> With Qt model/view, you *cannot* say:
>> - i'm about to remove something somewhere
>> - i'm about to remove something else somewhere else
>> - i'm have removed something somewhere
>> - i'm have removed something else somewhere else
>> Actually the above could work if 'something else' was a child of
>> 'something', which is not my case, since my root items have 2
>> children:
>> - an Edge list node, whith Edge children
>> - a Vertex list node, with vertex children
>> Now, you might say that it is not because the CGAL ArrangementObserver
>> doesn't behave in a friendly way for my use-case (QAbstractItemModel),
>> that it is broken.
>> True. Nonetheless, I tend to consider non-symetrical behaviour as
>> design errors. In SW design, it usually doesn't make sense to
>> construct something following an order and dis-construct it using a
>> completely different order.
>> What do you guys think?
>> Chris
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://sympa.inria.fr/sympa/info/cgal-discuss
