Re: [cgal-discuss] RANSAC shape detection, no primitive detected after multiple runs.
- To:
- Subject: Re: [cgal-discuss] RANSAC shape detection, no primitive detected after multiple runs.
- Date: Mon, 6 Mar 2017 14:33:16 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:l1piuBR432qzftwmoNdF4ljFyNpsv+yvbD5Q0YIujvd0So/mwa67bRWN2/xhgRfzUJnB7Loc0qyN4v2mBTRLvMzJ8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3Izkn9y1rpbcagENiDumaq5pNz23qx/Qv48Ym9hMMKE0nyDIp3xOM8tX32p1KVWP10Ln58K3+ths8j5Zpv4m6+ZPXKL/crgiXLJRByghKXFz78ru40qQBTCT72cRBz1F2iFDBBLIuUn3
Hello Andrew,
Thank you for your report, I investigated and it turns out that it is indeed a bug: the method clear() should call clear_shape_factories() but does not, which means that at every iterations, there's a new shape factory (for Planes) added (which explains why the algorithms gets slower and slower although I'm not sure why this makes it detect 0 shapes after a while). I'll fix this in the CGAL code. In the mean time, if you want your code to work with the current version, you can simply move the line ransac.add_shape_factory<Plane>();before the loop (right after "Efficient_ransac ransac;" for example). Best, -- Simon Giraudot, PhD R&D Engineer GeometryFactory - http://geometryfactory.com/ Le 19/02/2017 à 14:25, AndrewLiu a écrit : Hello, When I tried to use the "Point Set Shape Detection" package and ran the example code multiple times, the program seemed normal at first but would output zero primitive eventually. It seems that the "clear" operation called by the "set_input" function doesn't clear everything. Is there anything that I am missing? Thanks, Andrew Liu Here is the code: #include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/IO/read_xyz_points.h> #include <CGAL/Point_with_normal_3.h> #include <CGAL/property_map.h> #include <CGAL/Timer.h> #include <CGAL/number_utils.h> #include <CGAL/Shape_detection_3.h> #include <iostream> #include <fstream> // Type declarations typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel; typedef Kernel::FT FT; typedef std::pair<Kernel::Point_3, Kernel::Vector_3> Point_with_normal; typedef std::vector<Point_with_normal> Pwn_vector; typedef CGAL::First_of_pair_property_map<Point_with_normal> Point_map; typedef CGAL::Second_of_pair_property_map<Point_with_normal> Normal_map; // In Efficient_RANSAC_traits the basic types, i.e., Point and Vector types // as well as iterator type and property maps, are defined. typedef CGAL::Shape_detection_3::Efficient_RANSAC_traits<Kernel, Pwn_vector, Point_map, Normal_map> Traits; typedef CGAL::Shape_detection_3::Efficient_RANSAC<Traits> Efficient_ransac; typedef CGAL::Shape_detection_3::Plane<Traits> Plane; int main() { // Points with normals. Pwn_vector points; // Loads point set from a file. // read_xyz_points_and_normals takes an OutputIterator for storing the points // and a property map to store the normal vector with each point. std::ifstream stream("data/cube.pwn"); if (!stream || !CGAL::read_xyz_points_and_normals(stream, std::back_inserter(points), Point_map(), Normal_map())) { std::cerr << "Error: cannot read file cube.pwn" << std::endl; return EXIT_FAILURE; } // Instantiates shape detection engine. Efficient_ransac ransac; const Pwn_vector pts_origin = points; for (std::size_t i = 0; i < 30; ++i) { points = pts_origin; // Provides the input data. ransac.set_input(points); // Registers detection of planes ransac.add_shape_factory<Plane>(); // Measures time before setting up the shape detection. CGAL::Timer time; time.start(); // Build internal data structures. ransac.preprocess(); // Measures time after preprocessing. time.stop(); std::cout << "preprocessing took: " << time.time() * 1000 << "ms" << std::endl; // Perform detection several times and choose result with highest coverage. Efficient_ransac::Shape_range shapes = ransac.shapes(); FT best_coverage = 0; for (size_t i = 0; i < 6; i++) { // Reset timer. time.reset(); time.start(); // Detects shapes. ransac.detect(); // Measures time after detection. time.stop(); // Compute coverage, i.e. ratio of the points assigned to a shape. FT coverage = FT(points.size() - ransac.number_of_unassigned_points()) / FT(points.size()); // Prints number of assigned shapes and unsassigned points. std::cout << "time: " << time.time() * 1000 << "ms" << std::endl; std::cout << ransac.shapes().end() - ransac.shapes().begin() << " primitives, " << coverage << " coverage" << std::endl; // Choose result with highest coverage. if (coverage > best_coverage) { best_coverage = coverage; // Efficient_ransac::shapes() provides // an iterator range to the detected shapes. shapes = ransac.shapes(); } } } return EXIT_SUCCESS; } -- View this message in context: http://cgal-discuss.949826.n4.nabble.com/RANSAC-shape-detection-no-primitive-detected-after-multiple-runs-tp4662529.html Sent from the cgal-discuss mailing list archive at Nabble.com. |
- Re: [cgal-discuss] RANSAC shape detection, no primitive detected after multiple runs., Simon Giraudot, 03/06/2017
