cgal-discuss - [cgal-discuss] Surface reconstruction from a point cloud
  • To:
  • Subject: [cgal-discuss] Surface reconstruction from a point cloud
  • Date: Sat, 11 Mar 2017 07:06:15 -0800 (PST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:z3AG9RBUoybuol2AiS4AUyQJP3N1i/DPJgcQr6AfoPdwSP77pcbcNUDSrc9gkEXOFd2CrakV1qyL6+u+CCRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUrj71Jrmkrnqs92IO10J13KBZuZ5Ixyy6AnQrcILmpBKK6AryxKPrGEbVf5RwDZWJFSYkhDgruix9Zhs+j9Itugmv5peUKPxcqIkQ71EHnJ3a0g64cTqsV/ISg7ZtShUaXkfjhcdWluN1xr9RJqk6XOiuw==
Hello
I'm working on a 3D Shock Fitting solver for numerical computations of
hypersonic reentry flows and I included CGAL in my project. I need to
reconstruct a 3D triangular surface from a set of cloud points. I'm using
the CGAL Point Set Processing package for processing the cloud point set (
using WLOP-Normal Estimation-Smoothing) and the Advancing Front Surface
Reconstruction package for the surface mesh generation.
Being the first time I use CGAL, I'm quite happy for the results, but I need
to improve the quality of the reconstructed surface, in terms of number of
points and regularity of the edge. I tried to apply almost every possible
function and parameters value in the Point Set Processing package, without
any improvement on the overall quality. An important aspect of this
reconstruction is the location of the surface compared to point cloud. I
need to fit an "expected" position and shape of the surface, but upsampling
or smoothing differently the points gives me a bad fit.
Can you suggest me a different strategy for this surface reconstruction
problem? Is it possible to remesh my surface with a different package after
the reconstruction?
I attached the point cloud set ( just to give you an idea of the points
distribution ), the best result I got with CGAL and the "desired" surface I
would like to achieve ( in terms of smoothing and points sampling)
Thanks in advance for any assistance,
Vincent
<http://cgal-discuss.949826.n4.nabble.com/file/n4662584/snapshot02.png>
<http://cgal-discuss.949826.n4.nabble.com/file/n4662584/snapshot01.png>
<http://cgal-discuss.949826.n4.nabble.com/file/n4662584/snapshot00.png>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Surface-reconstruction-from-a-point-cloud-tp4662584.html
  • [cgal-discuss] Surface reconstruction from a point cloud, Vincent Giangaspero, 03/11/2017
