cgal-discuss - [cgal-discuss] mesh 2d with intersecting constraints seg faults while calling method refine_mesh()
  • To:
  • Subject: [cgal-discuss] mesh 2d with intersecting constraints seg faults while calling method refine_mesh()
  • Date: Wed, 15 Mar 2017 09:32:23 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:Nx60PBX5W2z+grTag3+23h4rThjV8LGtZVwlr6E/grcLSJyIuqrYZRODt8tkgFKBZ4jH8fUM07OQ6PG9HzFQqsbe+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiO/MjYbAxMwTa8erhvNw6erAPLt8BQj5ExBLw2z07nq3FJfKxswmZhI1Pbyxrm/du9/Zg8qgxfvvsg84hLVqCsLPdwdqBREDlzazN938bsrxSWFQY=
Hi,
Pretty new with CGAL coding. I'm trying to mesh shapes on different layers that could intersect each other.
I'm using this header file to setup my space:
#ifndef MESH_H
#define MESH_H
#include <CGAL/Constrained_Delaunay_triangulation_2.h>
#include <CGAL/Delaunay_mesher_2.h>
#include <CGAL/Delaunay_mesh_face_base_2.h>
#include <CGAL/Delaunay_mesh_vertex_base_2.h>
#include <CGAL/Delaunay_mesh_size_criteria_2.h>
#include <CGAL/lloyd_optimize_mesh_2.h>
#include <iostream>
#include <fstream>
#include <sstream>
#include <vector>
#include <list>
#include <string>
//#include <CGAL/Cartesian.h>
using namespace std;
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
//typedef CGAL::Triangulation_vertex_base_2<K> Vb;
typedef CGAL::Delaunay_mesh_vertex_base_2<K>                Vb;
typedef CGAL::Delaunay_mesh_face_base_2<K>                  Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb>        Tds;
typedef CGAL::Exact_predicates_tag                          Itag;
typedef CGAL::Constrained_Delaunay_triangulation_2<K, Tds, Itag>  CDT;
typedef CGAL::Delaunay_mesh_size_criteria_2<CDT>            Criteria;
typedef CGAL::Delaunay_mesher_2<CDT, Criteria>              Mesher;
typedef CDT::Vertex_handle Vertex_handle;
typedef CDT::Point         Point;
//typedef CGAL::Point_2<CGAL::Cartesian<double> >  Point;
class Mesh {
    CDT cdt;
    list< vector<Vertex_handle> > polygons;
    vector<Vertex_handle> polygon;
    // seeds are points that falls inside holes in the polygons
    // this is the way that the algorithm knows how to avoid
    // filling the holes
    std::list<Point> list_of_seeds;
public:
    Mesh();
    ~Mesh();
    Vertex_handle add_point(Point point);
    void add_constraint(Vertex_handle va, Vertex_handle vb);
    void add_seed(Point point);
    long n_vertices();
    Mesher run(Criteria criteria = Criteria(), bool optimize = false);
    void export_triangles_points(std::ofstream &cf, Mesher mesher);
    void read_polygons(ifstream &cf);
    bool import_database(ifstream &cf);
and this method to import my points:
void
Mesh::read_polygons(ifstream &cf)
    // type == [polygon, hole, point]
    string type, layer, net;
    int    npoly = 0, nhole = 0, npoint = 0;
    while(cf >> type)
        unsigned long int n;
        if( type == "polygon" )
            polygon.clear();
            // reading layer
            cf >> layer;
            // reading net
            cf >> net;
            // reading number of points
            cf >> n;
            cout << "*INFO* Importing polygon #" << ++npoly << " (" << n << " vertices)" << endl;
            while( n-- )
                Point p;
                cf >> p;
//                p.add_property_map<Vertex_handle, string>().first;
                polygon.push_back(cdt.insert(p));
            // adding constraints
            for( int i = 1; i < polygon.size(); i++ )
                cdt.insert_constraint(polygon[i-1], polygon[i]);
            cdt.insert_constraint(polygon[polygon.size()-1], polygon[0]);
        else if( type == "point" )
            cout << "*INFO* Importing point #" << ++npoint << endl;
            Point p;
            cf >> p;
            cdt.insert(p);
        else
and then I just run the mesher:
Mesher
Mesh::run(Criteria criteria, bool optimize)
    Mesher mesher(cdt);
    mesher.set_criteria(criteria);
    cout << "HEREEEEEEE" << endl;
    mesher.refine_mesh();
    if( optimize )
        cout << "*INFO* Running lloyd optimizer..." << endl;
        // optimizing mesh
        CGAL::lloyd_optimize_mesh_2(cdt, CGAL::parameters::max_iteration_number = 10);
    return mesher;
everything works ok if I don't have intersecting constraints...but at times I do and the program just seg faults.
According to the documentation online, CGAL should support intersecting constraints, so it could be just a matter of me not setting the CDT template properly.
Any help appreciated!
Thank
Fabio
