Re: [cgal-discuss] problem/bug with CGAL::Polygon_mesh_processing::is_outward_oriented()
- To:
- Subject: Re: [cgal-discuss] problem/bug with CGAL::Polygon_mesh_processing::is_outward_oriented()
- Date: Thu, 6 Apr 2017 17:35:00 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hi Hugo,
thanks for your report. I am having a look at it.
Best,
Jane.
Le 06/04/2017 à 11:27, Hugo Ledoux a écrit :
Greetings,
I have one mesh whose normals are pointing outwards, but the function
CGAL::Polygon_mesh_processing::is_outward_oriented() returns
otherwise.
I have checked the code and the average of the normals of the faces
incident to the min-vertex is used, which conceptually I doubt should
work… And it doesn’t work in my case (unless I made a mistake
somewhere), you can download my OFF file, along with the code I used,
there:
https://www.dropbox.com/sh/49as9yt139v6kxk/AABXI3Nh4ZfqCEDWHyv8Q-Zja?dl=0
If other ways to compute the normal were used (eg by using the area of
the face as a weight), then the x-component of the vector could be
negative (as is used by cgal), but I am wondering if that would always
work. I think not.
Any comments appreciated, cheers,
Hugo Ledoux
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] problem/bug with CGAL::Polygon_mesh_processing::is_outward_oriented(), Hugo Ledoux, 04/06/2017
- Re: [cgal-discuss] problem/bug with CGAL::Polygon_mesh_processing::is_outward_oriented(), Jane Tournois, 04/06/2017
- Re: [cgal-discuss] problem/bug with CGAL::Polygon_mesh_processing::is_outward_oriented(), Jane Tournois, 04/14/2017
- Re: [cgal-discuss] problem/bug with CGAL::Polygon_mesh_processing::is_outward_oriented(), Hugo Ledoux, 04/21/2017
