cgal-discuss - Re: [cgal-discuss] Conforming Delaunay Triangulation 2.5D
  • To:
  • Subject: Re: [cgal-discuss] Conforming Delaunay Triangulation 2.5D
  • Date: Thu, 6 Apr 2017 12:26:51 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
You have to use Gt instead of K on the cdt typedef
typedef
CGAL::Constrained_Delaunay_triangulation_2<Gt, TDS, Itag> CDT;
I had trouble getting it to work thought with the exact tag. Use CDT::Point to get the point, its less error-prone.
Cheers and gl!
El dia 06/04/2017 11:39, "Pol M" <> va escriure:
typedef
Cheers and gl!
El dia 06/04/2017 10:46, "Renato Silveira" <> va escriure:
I saw the example using Delaunay Triangulation 2.5D and everything works fine.
Is it possible to use Conforming Delaunay Triangulation with CGAL::Projection_traits_xy_3?
I'm trying using this setup:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Projection_traits_xy_3<K> Gt;
typedef CGAL::Triangulation_vertex_base_with_info_2<std::string, Gt> Vb;
typedef CGAL::Constrained_triangulation_face_base_2<Gt>                 Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> TDS;
typedef CGAL::Exact_predicates_tag Itag;
typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS, Itag> CDT;
typedef K::Point_3   Point_CDT;
I can't insert a Point_3 on a CDT. I tried using CGAL::No_intersection_tag to avoid create new points with no success.
Is there a way to use Conforming Delaunay Triangulation 2.5D?
Renato Silveira
     Ph.D. in Computer Science
     Informatics Institute - UFRGS
     Porto Alegre - RS - Brazil
