- To: <>
- Subject: Re: [cgal-discuss] Export 3d delaunay triangulation
- Date: Sat, 13 May 2017 09:01:17 -0600
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi Mozendi,
I am using CGAL to do something similar as you (build a triangulation of terrain from a set of points)
I don't think the triangulation_3 is what you want. The 3D triangulation allows for connecting the vertexes in 3-space whereas what I think you want is a 2.5D mesh. That is, your vertexes have elevation, but the triangulation is only connected in 2D.
An example of what I'm doing is found here
If this what you want, the key is to use vertexes that have 3D information (x,y,z), but the triangulation exists on a plane.
The projection_traits_xy_3 is required as it allows for using the 2D algorithms on the 3D vertexes.
For outputting, I use the VTU format from the VTK library and visualise in VTK. You have to manually build the vtk datastructure from the cgal triangulation though. It is straightforward but non-trivial.
Otherwise I would just build the STL file yourself.
Hope this helps
Cheers
Chris
On 12 May 2017 at 16:25, mozendi <> wrote:
Dear CGAL users,
I am a new CGAL user. My objective is to create 3d delaunay triangulation
from terrestrial LIDAR points clouds. So that, each point of the cloud will
be set as a vertex.
After some efforts on CGAL I came up with the code below:
// types
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef Kernel::Point_3 Point;
typedef Kernel::Vector_3 Vector;
typedef CGAL::Triangulation_vertex_base_with_info_3<unsigned, Kernel> Vb;
typedef CGAL::Triangulation_data_structure_3<Vb> Tds;
typedef CGAL::Delaunay_triangulation_3<Kernel, Tds, CGAL::Fast_location>
Delaunay;
typedef Delaunay::Point Point;
int main(int argc, char*argv[])
// Reads a .xyz point set file in points[].
std::vector<Point> points;
std::vector<Vector> normals;
const char* fname = (argc>1) ? argv[1] :
"data/SIL_ARKA_1cm_POINTS_NORMALS.xyz";
std::ifstream stream(fname);
Point p;
Vector v;
while (stream >> p >> v) {
points.push_back(p);
normals.push_back(v);
std::vector<std::size_t> indices(points.size());
for (std::size_t i = 0; i < points.size(); ++i) {
indices[i] = i;
std::cout << "Point Cloud is Loaded" << std::endl;
std::cout << points.size() << " input points" << std::endl;
std::cout << " -------------------------------" << std::endl;
std::cout << " START BUILDING THE TRIANGULATION" << std::endl;
Delaunay T(points.begin(), points.end());
std::cout << " TRIANGULTION COMPLETED" << std::endl;
std::ofstream oFileT("testFile1", std::ios::out);
oFileT << T;
return EXIT_SUCCESS;
As a result of this program I get the txt file "testFile1". However, I could
not find any description for this file. Is it possible to convert this file
to well known file formats such as .ply, .stl or .obj. Moreover, do you
think is it the correct way of creating 3D delaunay triangulation from point
clouds that are stored in .xyz file?
I am looking forward to hearing from you
Regards
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Export-3d-delaunay-triangulation-tp4662725.html
- [cgal-discuss] Export 3d delaunay triangulation, mozendi, 05/13/2017
- Re: [cgal-discuss] Export 3d delaunay triangulation, Monique Teillaud, 05/13/2017
- Re: [cgal-discuss] Export 3d delaunay triangulation, Chris Marsh, 05/13/2017
- Re: [cgal-discuss] Export 3d delaunay triangulation, mozendi, 05/13/2017
