cgal-discuss - Re: [cgal-discuss] Export 3d delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] Export 3d delaunay triangulation
  • Date: Sat, 13 May 2017 12:13:27 -0700 (PDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23: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
Dear Chris,
Thank you for the explanations. Honestly speaking I am confused a little
about the 2.5D and 3D case. My dataset is terrestrial laser scanner derived
point clouds. Many points may have the same z or elevation value. In this
case, do you think 2D triangulation will work? By the way, I can not see the
imgur link from my country. Could you please send me another link?
Regards
Mustafa
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Export-3d-delaunay-triangulation-tp4662725p4662728.html
