- To:
- Subject: [cgal-discuss] problem building demos with Qt5
- Date: Mon, 26 Jun 2017 22:40:03 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=PermError ; spf=None
- Ironport-phdr: 9a23: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
I've downloaded and installed CGAL-4.10 on Mac OS 10.10.5
I build and compiled with Qt5 and got the following libraries
~/cgal-releases-CGAL-4.10/build/lib/ :
libCGAL.13.0.0.dylib libCGAL_Core.13.0.0.dylib
libCGAL_ImageIO.13.0.0.dylib
libCGAL_Qt5.13.0.0.dylib
libCGAL.13.dylib libCGAL_Core.13.dylib
libCGAL_ImageIO.13.dylib
libCGAL_Qt5.13.dylib
libCGAL.dylib libCGAL_Core.dylib
libCGAL_ImageIO.dylib libCGAL_Qt5.dylib
I set the CGAL_DIR=~/cgal-releases-CGAL-4.10/build
I then tried to compile demos for Periodic_3_triangulation_3:
In the directory
~/cgal-releases-CGAL-4.10/Periodic_3_triangulation_3/demo/Periodic_3_triangulation_3
I ran
> cmake .
and get the following
-- libCGAL_Qt5 is missing the dependencies: Qt5OpenGL Qt5Svg Qt5 cannot be
configured.
-- NOTICE: The CGAL_Qt5 library was not configured.
-- Build type: Release
-- USING CXXFLAGS = ' -O3 -DNDEBUG'
-- USING EXEFLAGS = '
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
-- Targetting Unix Makefiles
-- Using
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++
compiler.
-- DARWIN_VERSION=14
-- Mac Leopard detected
-- Code taken from Git branch: n/a
-- Requested component: Qt5
-- Requested component: MPFR
-- Requested component: GMP
-- NOTICE: This demo requires qcollectiongenerator, Qt5, the CGAL Qt5
library, and will not be compiled.
-- Configuring done
-- Generating done
-- Build files have been written to:
/Users/vanessa/Software/cgal-releases-CGAL-4.10/Periodic_3_triangulation_3/demo/Periodic_3_triangulation_3
I don't understand why cmake can't find the CGAL_Qt5 library.
Grateful for any advice you can give me.
Kind regards,
Vanessa
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/problem-building-demos-with-Qt5-tp4662789.html
- [cgal-discuss] problem building demos with Qt5, robinsv, 06/27/2017
- Re: [cgal-discuss] problem building demos with Qt5, Sebastien Loriot (GeometryFactory), 06/27/2017
- Re: [cgal-discuss] problem building demos with Qt5, Vanessa Robins, 06/27/2017
- Re: [cgal-discuss] problem building demos with Qt5, Sukhraj Singh, 06/27/2017
- Re: [cgal-discuss] problem building demos with Qt5, Monique Teillaud, 06/28/2017
