- To:
- Subject: Re: [cgal-discuss] problem building demos with Qt5
- Date: Wed, 28 Jun 2017 06:19:21 +0200
Hi
After struggling, googling, reading stack overflow, etc, we found the solution. It is just a (stupid) Mac thing.
~/Library/Frameworks must contain a symbolic link to (path)/libQGLViewer-xx/QGLViewer/QGLViewer.framework
Just manually adding the link eventually allowed the periodic_3.._demo to work.
A cube has never looked so nice!! ;)
Monique Teillaud
https://members.loria.fr/Monique.Teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
Thanks for that quick reply!
I set the Qt5_DIR environment variable, and also QGLVIEWERROOT=/usr/local/libQGLViewer-2.7.0
This allowed cmake to run and make also compiled with no complaints.
But then trying to run the demo I get
./periodic_3_triangulation_3_demo
dyld: Library not loaded: QGLViewer.framework/Versions/2/QGLViewer
Referenced from: /Users/vanessa/Software/cgal-releases-CGAL-4.10/Periodic_3_triangulation_3/demo/Periodic_3_triangulation_3/./periodic_3_triangulation_3_demo
Reason: image not found
Trace/BPT trap: 5
Any hints on this one?
Regards,
Vanessa
- [cgal-discuss] problem building demos with Qt5, robinsv, 06/27/2017
- Re: [cgal-discuss] problem building demos with Qt5, Sebastien Loriot (GeometryFactory), 06/27/2017
- Re: [cgal-discuss] problem building demos with Qt5, Vanessa Robins, 06/27/2017
- Re: [cgal-discuss] problem building demos with Qt5, Sukhraj Singh, 06/27/2017
- Re: [cgal-discuss] problem building demos with Qt5, Monique Teillaud, 06/28/2017
