- To:
- Subject: Re: [cgal-discuss] Polysurf does not load my .off files correctly
- Date: Tue, 27 Jun 2017 13:53:57 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
It must be a two-manifold, that is not more than two faces
sharing an edge.
andreas
On 27/06/2017 13:51, Joan Hensen wrote:
Dear community,
I have several meshes given as .off files, which I would like to load in
the following way:
PolyhedralSurf P;
std::ifstream stream(if_name.c_str());
stream >> P;
But neither vertices nor facets are loaded.
Please check this
( https://www.dropbox.com/s/2dkt0idgzdy1atq/example.off?dl=0 ) example
file out the attached file and tell me what I could do, please.
Best,
Joan
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Polysurf does not load my .off files correctly, Joan Hensen, 06/27/2017
- Re: [cgal-discuss] Polysurf does not load my .off files correctly, Andreas Fabri, 06/27/2017
- Re: [cgal-discuss] Polysurf does not load my .off files correctly, Sebastien Loriot (GeometryFactory), 06/27/2017
- AW: [cgal-discuss] Polysurf does not load my .off files correctly, Joan Hensen, 06/27/2017
