cgal-discuss - Re: [cgal-discuss] Polysurf does not load my .off files correctly
  • To:
  • Subject: Re: [cgal-discuss] Polysurf does not load my .off files correctly
  • Date: Tue, 27 Jun 2017 13:56:25 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
On 06/27/2017 01:53 PM, Andreas Fabri wrote:
It must be a two-manifold, that is not more than two faces
sharing an edge.
+ you have some pinched vertices (at least 2 umbrella of faces around some vertices)
andreas
On 27/06/2017 13:51, Joan Hensen wrote:
Dear community,
I have several meshes given as .off files, which I would like to load in
the following way:
PolyhedralSurf P;
std::ifstream stream(if_name.c_str());
stream >> P;
But neither vertices nor facets are loaded.
Please check this
( https://www.dropbox.com/s/2dkt0idgzdy1atq/example.off?dl=0 ) example
file out the attached file and tell me what I could do, please.
Best,
Joan
