cgal-discuss - Re: [cgal-discuss] sibson_gradient_fitting_nn_2 failing in with Exact_predicates_inexact_constructions_kernel
  • To:
  • Subject: Re: [cgal-discuss] sibson_gradient_fitting_nn_2 failing in with Exact_predicates_inexact_constructions_kernel
  • Date: Tue, 25 Jul 2017 13:34:55 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:Xup9DRU49wGqEJ4cEkpyuN/6tC7V8LGtZVwlr6E/grcLSJyIuqrYbBGCt8tkgFKBZ4jH8fUM07OQ6PGwHzRYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjSwbLdxIRmssQndqtQdjJd/JKo21hbHuGZDdf5MxWNvK1KTnhL86dm18ZV+7SleuO8v+tBZX6nicKs2UbJXDDI9M2Ao/8LrrgXMTRGO5nQHTGoblAdDDhXf4xH7WpfxtTb6tvZ41SKHM8D6Uaw4VDK/5KptVRTmijoINyQh/W/KlMJwgqJVoBWiqRJxzYHbb4OaO+ZxcK7GYdMXR3BMUtpNWyFPAo6xaZYEAeobPeZfqonwv1UCowagCga3Huzv0SNIhn7o0q08zu8vFwbG3BYhH9IJrHTfsdH5OqYMXuCyyanH0ynDb+lW2Dn98ofHbgwhofaWXbNwdMbdx1QkGgTejlWUrozlJTKV1uMRs2SB6upgUfmii2Eiqw5rozivwt0ghZXOhoIQ013J8zhyzogyJd29UkF7YNikHYNWty6ALIR5WcciTH9ytCkmzb0GvJi2dzUJxpQ/3xPTdeCLfoyS7h/gVOudOyp0iGxmdb6lmhq/80atxvX+W8S3ylpGsCVIn9jWunwQ0xHe5NKLR/l980qnxD2BzRrc6vteLkAxjafbK4Auwro3lpcLtETMBC72mEHvgK6YbEUo5vGk6+r6brjkqJKQLYB0igb5MqQhnsywH/40PRQJX2ie4ei81bvj8lPlQLhSkPE6jq3UvIrZKMkbvKK1HhFZ34U55xqiDTqr3swUnXwdI1JEfBKHgZLpO1bLIP3gFve/h1OskC1qx/DBIr3tGJDNLnzYnbfueLZy8U9cyA4pwd9D4JJUD6kNIOjvVU/pqNzYEhg5PhSozOboEtp90poSVn+OAq+CLKzSrESI5vk0LumXZI4VvS79JOI/6/7vi385g14dcrOz0ZsZcnDrVshhdk6WaH6pjtYaGnoRpSI/SvbrgRuMS219fXG3CugH6zsyE56nAIGLYoe3gbudlGeUE5pTa3xcG36FGmvvbZTFEb9YcyaVOM5mjnoBUZCuToYg0VelswqsmOkvFfbd5iBN7cGr79Ny/eCGzRw=
Would you have a minimal example showing the pb?
Sebastien.
On 07/20/2017 08:56 PM, tallan wrote:
Hi guys,
I am having an issue trying to use Sibsons C^1 interpolation on my data. If
I use Exact_predicates_inexact_constructions_kernel, then
sibson_gradient_fitting_nn_2 fails with the error:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: ! CGAL_NTS is_zero(den)
File: /usr/include/CGAL/constructions/kernel_ftC2.h
Line: 62
If I use Simple_cartesian<long double>, then the process hasn't crashed, but
did not finish after over 24 hours. This is with an unstructured mesh with
~2.7 M triangles after triangulation.
I suppose this is a numerical error. Is than any known workaround to this
problem?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/sibson-gradient-fitting-nn-2-failing-in-with-Exact-predicates-inexact-constructions-kernel-tp4662850.html
