- To:
- Subject: Re: [cgal-discuss] 3D demos when run gives segmentation fault
- Date: Tue, 25 Jul 2017 13:31:00 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 07/25/2017 12:43 PM, neeta wrote:
I installed CGAL. My 2D demos work fine. 3D demos "make" works fine, no
errors. But when its run, it gives segmentation fault
Did you check that your libQglviewer was compiled with Qt5 and no Qt4?
Without additional information (platform, compiler, CGAL version) it is hard to help further.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-demos-when-run-gives-segmentation-fault-tp4662856.html
- [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, Sebastien Loriot (GeometryFactory), 07/25/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/26/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, neeta, 07/31/2017
- Re: [cgal-discuss] 3D demos when run gives segmentation fault, Sebastien Loriot (GeometryFactory), 07/31/2017
