cgal-discuss - Re: [cgal-discuss] Undefined symbol while linking against Cgal
  • To:
  • Subject: Re: [cgal-discuss] Undefined symbol while linking against Cgal
  • Date: Fri, 4 Aug 2017 09:06:16 -0700 (PDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23: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
I was finally able to compile CGAL with gcc 7. I had to disable the following
test in CGAL_SetupBoost.cmake:
* try_run( CGAL_test_cpp_version_RUN_RES CGAL_test_cpp_version_COMPILE_RES
"${CMAKE_BINARY_DIR}"
"${CGAL_INSTALLATION_PACKAGE_DIR}/config/support/CGAL_test_cpp_version.cpp"
RUN_OUTPUT_VARIABLE CGAL_cplusplus)*
The test was apparently failing while compiling with gcc 7, causing
CGAL_requires_Boost_libs to be set to FALSE and preventing linking with the
boost libraries. I should have noticed the smoking gun in the earlier cmake
traces, with the boost libraries that were left unset.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Undefined-symbol-while-linking-against-Cgal-tp4662876p4662883.html
