- To: "" <>
- Subject: [cgal-discuss] CGAL Boost MSVC2015 problem
- Date: Tue, 8 Aug 2017 11:51:14 +0000 (UTC)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Does anyone know what can be the reason for these errors I am getting?
I have compiled and build different versions of CGAL including: 4.10 4.9 and 4.8.2 with Qt5.6.2 and Boost 1.6.2 and 1.6.4 for MSVC2015 x64 and I program in Release.
I include the CGAL and Boost directories and files in MSVC as in this image:
When I try to run an empty main with an #include:
#include <iostream>
int main()
return 0;
I get the following errors:
1>------ Rebuild All started: Project: ConsoleApplication1, Configuration: Release x64 ------
1> Source.cpp
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(18): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(18): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(18): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(18): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(18): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(38): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(38): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(46): error C2061: syntax error: identifier '_General_ptr_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(64): error C2061: syntax error: identifier '_Really_trivial_ptr_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(67): error C2995: '_FwdIt std::_Uninitialized_copy_unchecked1(_InIt,_InIt,_FwdIt)': function template has already been defined
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(45): note: see declaration of 'std::_Uninitialized_copy_unchecked1'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(81): error C2061: syntax error: identifier 'input_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(90): error C2061: syntax error: identifier 'random_access_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(95): error C2995: '_FwdIt std::_Uninitialized_copy1(_InIt,_InIt,_FwdIt)': function template has already been defined
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(80): note: see declaration of 'std::_Uninitialized_copy1'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(126): error C2061: syntax error: identifier '_General_ptr_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(145): error C2061: syntax error: identifier '_Really_trivial_ptr_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(150): error C2995: '_FwdIt std::_Uninitialized_copy_n_unchecked1(_InIt,_Diff,_FwdIt)': function template has already been defined
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(125): note: see declaration of 'std::_Uninitialized_copy_n_unchecked1'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(219): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(238): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(247): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(258): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(272): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(291): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(300): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(312): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(414): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(414): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(414): error C2143: syntax error: missing ',' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(431): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(431): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(431): error C2143: syntax error: missing ',' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(435): error C2995: 'void std::_Uninit_alloc_fill_n1(_FwdIt,_Diff,const int)': function template has already been defined
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(414): note: see declaration of 'std::_Uninit_alloc_fill_n1'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(441): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(441): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(441): error C2143: syntax error: missing ',' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(452): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(469): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(472): error C2995: 'void std::_Uninitialized_default_fill_n1(_FwdIt,_Diff)': function template has already been defined
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(451): note: see declaration of 'std::_Uninitialized_default_fill_n1'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(478): error C2061: syntax error: identifier '_Wrap_alloc'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(22): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(22): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(22): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(22): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(22): error C2374: 'std::pair': redefinition; multiple initialization
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xmemory(18): note: see declaration of 'std::pair'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(22): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(67): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(67): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(133): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(133): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(133): error C2433: 'iterator_traits': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(133): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(133): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(148): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(148): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(157): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(157): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(157): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(157): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(157): error C2374: 'std::pair': redefinition; multiple initialization
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(157): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(176): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(176): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(184): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(184): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(184): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(184): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(184): error C2374: 'std::pair': redefinition; multiple initialization
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(184): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(198): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(198): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(209): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(209): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(209): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(209): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(209): error C2374: 'std::pair': redefinition; multiple initialization
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(209): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(238): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(238): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(260): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(260): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(260): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(260): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(260): error C2374: 'std::pair': redefinition; multiple initialization
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(260): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(280): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(280): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(292): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(292): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(292): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(292): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(292): error C2374: 'std::pair': redefinition; multiple initialization
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(292): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(304): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(304): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(435): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(435): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(435): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(435): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(435): error C2374: 'std::pair': redefinition; multiple initialization
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(435): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(461): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(461): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(472): error C2988: unrecognizable template declaration/definition
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(472): error C2143: syntax error: missing ';' before '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(472): error C2433: 'pair': 'inline' not permitted on data declarations
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(472): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(472): error C2374: 'std::pair': redefinition; multiple initialization
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(472): error C2059: syntax error: '<'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(535): error C2143: syntax error: missing ';' before '{'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(535): error C2447: '{': missing function header (old-style formal list?)
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(593): error C2061: syntax error: identifier 'forward_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(613): error C2061: syntax error: identifier 'random_access_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(629): error C2995: '_FwdIt1 std::_Search_unchecked(_FwdIt1,_FwdIt1,_FwdIt2,_FwdIt2,_Pr &)': function template has already been defined
1> C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(591): note: see declaration of 'std::_Search_unchecked'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(662): error C2061: syntax error: identifier 'forward_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(693): error C2061: syntax error: identifier 'random_access_iterator_tag'
1>C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\algorithm(693): fatal error C1003: error count exceeds 100; stopping compilation
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Thanks,
Majid
#include <iostream>
int main()
return 0;
1> Source.cpp
Thanks,
Majid
- [cgal-discuss] CGAL Boost MSVC2015 problem, Majid Mohammad sadeghi, 08/08/2017
