cgal-discuss - Re: [cgal-discuss] 3D Mesh Generation: How to enable parallel meshing
  • To:
  • Subject: Re: [cgal-discuss] 3D Mesh Generation: How to enable parallel meshing
  • Date: Thu, 17 Aug 2017 09:02:43 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:2Bu8MhUb0qDzjEJzQDlI7Z+eChXV8LGtZVwlr6E/grcLSJyIuqrYZR2Pt8tkgFKBZ4jH8fUM07OQ6P+wHzFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aLDykalEwfri9WtOKzpf/6+fn8JLaZ0BEhSG2fKhpBBSwtwTY8McM0qV4LaNkgCDEqHJTZ+VbwytMIkiSmAq0pui9+5tu7z5Blfsq68laQOSwN/AjSbtCDTM6dWUxzMLuvBjHCwCI4y1PAS0tjhNUDl2dv1nBVZDrv36n7uc=
On 08/16/2017 12:17 PM, Michael Bieri wrote:
Hi all
The CGAL documentation just says that I have to enable the parallel tag,
like:
typedef CGAL::Parallel_tag Concurrency_tag;
typedef
CGAL::Mesh_triangulation_3<Mesh_domain,CGAL::Default,Concurrency_tag>::type
Tr;
Surprisingly, it compiled right after that modification, even though I
neither set any link flags for the Intel TBB nor did I find any traces
that I already have Intel TBB on my system (Mac Book Pro) at all.
If you copy-paste a cmake script from CGAL it might be automatically
done. I know this a proposal to issue a warning when the user ask
for parallel support while it is not available but it was not
implemented IIRC. One way to check is to verify that
CGAL_LINKED_WITH_TBB is defined.
Otherwise have a look at this cmake script for example:
https://github.com/CGAL/cgal/blob/master/Mesh_3/examples/Mesh_3/CMakeLists.txt
What exactly do I need to do to use parallel meshing? How can I control
the number of threads? Is there an example?
You should refer to the Intel TBB documentation.
Something like this should work:
tbb::task_scheduler_init tsi(6); // 6 threads
run_parallel_algo1(); // Uses 6 threads
Sebastien.
Thanks a lot and best regards,
Michael
