- To:
- Subject: [cgal-discuss] 3D Mesh Generation: How to enable parallel meshing
- Date: Wed, 16 Aug 2017 12:17:37 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:h+effxLM2qAV6d5ZXdmcpTZWNBhigK39O0sv0rFitYgXL/TxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uDUdExG6OQtuLfnuAabTid623qa84c79eQJN0R+8arN7IRH+hwTcrMhe1Y5jIKc80BrhrX5BeuAQzmRtcwHA1y3g79u9qcYwux9bvOgsopZN
Hi all
The CGAL documentation just says that I have to enable the parallel tag, like:
typedef CGAL::Parallel_tag Concurrency_tag;
typedef CGAL::Mesh_triangulation_3<Mesh_domain,CGAL::Default,Concurrency_tag>::type Tr;
Surprisingly, it compiled right after that modification, even though I neither set any link flags for the Intel TBB nor did I find any traces that I already have Intel TBB on my system (Mac Book Pro) at all.
What exactly do I need to do to use parallel meshing? How can I control the number of threads? Is there an example?
Thanks a lot and best regards,
Michael
- [cgal-discuss] 3D Mesh Generation: How to enable parallel meshing, Michael Bieri, 08/16/2017
- Re: [cgal-discuss] 3D Mesh Generation: How to enable parallel meshing, Sebastien Loriot (GeometryFactory), 08/17/2017
- Re: [cgal-discuss] 3D Mesh Generation: How to enable parallel meshing, Michael Bieri, 08/17/2017
