- To:
- Subject: [cgal-discuss] CGAL::Euler::collapse_edge doc
- Date: Wed, 6 Sep 2017 05:24:32 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:4A1I3RR+5zjsZJFFh4yZyOqMrtpsv+yvbD5Q0YIujvd0So/mwa67YhyN2/xhgRfzUJnB7Loc0qyN7PCmBDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYkM06hZE8sfqy1QdaKzpf/6+fn8JLaZ0BEhSG2fKhpBBSwtwTY8McM0qV4LaNk6xLSpX1NM7BP3H9vIV+Vkj7z486x+Nho9CEG6KFpzNJJTaivJvdwdrdfFjlzaDht6Q==
Hello,
here
<https://doc.cgal.org/latest/Surface_mesh_simplification/classEdgeCollapsableSurfaceMesh.html>
it is actually described what results the collapse_edge function produces,
therefore I believe it would be helpful that at least this explanation is
copied (if not moved) to the collapse_edge doc
<https://doc.cgal.org/latest/BGL/group__PkgBGLEulerOperations.html#gab97c0d071b0d768e22a4fc171a8ca664>
Best Regards,
IM
- [cgal-discuss] CGAL::Euler::collapse_edge doc, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge doc, Sebastien Loriot (GeometryFactory), 09/06/2017
