- To:
- Subject: Re: [cgal-discuss] CGAL::Euler::collapse_edge doc
- Date: Wed, 6 Sep 2017 14:29:25 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:qy9wuRKW3xPnD0e/5NmcpTZWNBhigK39O0sv0rFitYgXIvjxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uDUdExG6OQtuLfnuAabTid623qa84c79eQJN0XCGbLl7Nwm3oAOZks4MgIx+YuYexxzMr2dSaspfzn9vP0PS1V6o/cO35p9k72JVv9ou8sdBVePxeKFuHu8QNygvL21gvJ6jjhLEVwbavnY=
I submitted this issue to track the progress:
https://github.com/CGAL/cgal/issues/2397
Feel free to add comments directly in the ticket.
Sebastien.
On 09/06/2017 02:24 PM, Iasonm wrote:
Hello,
here
<https://doc.cgal.org/latest/Surface_mesh_simplification/classEdgeCollapsableSurfaceMesh.html>
it is actually described what results the collapse_edge function produces,
therefore I believe it would be helpful that at least this explanation is
copied (if not moved) to the collapse_edge doc
<https://doc.cgal.org/latest/BGL/group__PkgBGLEulerOperations.html#gab97c0d071b0d768e22a4fc171a8ca664>
Best Regards,
IM
- [cgal-discuss] CGAL::Euler::collapse_edge doc, Iasonm, 09/06/2017
- Re: [cgal-discuss] CGAL::Euler::collapse_edge doc, Sebastien Loriot (GeometryFactory), 09/06/2017
