- To:
- Subject: [cgal-discuss] 3D mesh generation: Cheese model
- Date: Thu, 21 Sep 2017 22:15:48 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
- Ironport-phdr: 9a23:K6gaaBGbC9SfIhSuElqKIp1GYnF86YWxBRYc798ds5kLTJ76ocqwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWExGVMS1CmbUI1fbytW92as8Pi3O+7/9jfYh5DmSGmSbJ0NhS/6wvL5ecMho43GKExwwGB9mlPe+1MwThANFuTmBG67cC1qs0wux9Msu4sopcTGZ7xeL41GOcAVDk=
There's the cheese.off model supplied with the Mesh_3 examples. I'm using
the surface_mesher.zip Windows demo (downloaded from the website). I'd like
to remesh the cheese (generate a surface triangle mesh) while keeping the
features, <100k triangles, and 1 component manifold.
There are two different packages that supposed to do the same thing, but as
far as I recall, the second one is more robust.
In any case, I tried both packages with various parameters, but I couldn't
get the output that I want. Can you please help me with that?
By the way, the demo links are currently invalid, probably due to the new
CGAL version.
https://www.cgal.org/demo//surface_mesher.zip
http://www.cgal.org/demo//CGAL-demoDLLs.zip
- [cgal-discuss] 3D mesh generation: Cheese model, Zohar, 09/22/2017
