Re: [cgal-discuss] CGAL 4.11 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.11 Released, Computational Geometry Algorithms Library
- Date: Fri, 22 Sep 2017 20:03:34 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:VTJWvxzKnjK597DXCy+O+j09IxM/srCxBDY+r6Qd0uwTIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi54jcWXxn+LgFoPf/dG4jIjs3x2frh1YfUZlBqgzO2YbJ3ZC+7rA7Ru81e1YllI60xyx6PuHZJcORbwUtnIELVkxuqtZT4x4Jq7ykF46FpzMVHS6ivJ6k=
On 21.09.2017 14:17, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.11
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.11 are now available as well. Simply add
deb http://debian.cgal.org stretch main
deb-src http://debian.cgal.org stretch main
deb http://debian.cgal.org buster main
deb-src http://debian.cgal.org buster main
to /etc/apt/sources.list (you only need the pair of lines corresponding
to the release you are using). For experimental, packages should be
available from the official Debian repository in a few hours. The
packages are called libcgal13, libcgal-dev, libcgal-qt5-13,
libcgal-qt5-dev, libcgal-demo, and libcgal-ipelets.
In case you want to download the packages manually, have a look at
http://debian.cgal.org/pool/main/c/cgal/ .
See also http://www.cgal.org/FAQ.html#debian_packages .
Joachim
- [cgal-discuss] CGAL 4.11 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 09/21/2017
- Re: [cgal-discuss] CGAL 4.11 Released, Computational Geometry Algorithms Library, Joachim Reichel, 09/22/2017
