[cgal-discuss] convex polyhedron from planar halfspaces using double coordinates?
- To:
- Subject: [cgal-discuss] convex polyhedron from planar halfspaces using double coordinates?
- Date: Mon, 25 Sep 2017 16:38:03 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:oWl3BBwssKSiI2zXCy+O+j09IxM/srCxBDY+r6Qd0uwfIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi54jcWXxn+LgFoPf/dG4jIjs3x2frh1YfUZlBtjTOnfb50ZDCxoB7csIFChIJrMLo8zCzMpXZTduJ+xX5uOUmWlhC67cC1qs0wux9Msu4sopYTGZ7xeL41GORV
Dear CGAL community,
Today I tried computing the bounded convex polyhedron that is within a set of planar halfspaces using the NEF_3 library (CGAL 4.10). The equations of my input planes are given by doubles, and are thus not integer. I used the Exact_predicates_exact_constructions_kernel, but apparently there is no constructor for Nef_polyhedron::Plane_3.
Is there another kernel that I can use with double coordinates (and convert again to doubles once I have the solution?). Or is there another practical way to compute the convex polyhedron?
Best regards,
Maarten Moesen
Maarten Moesen, PHD
Polymer Physicist Computational Modeling
HUNTSMAN (Europe) BVBA
Everslaan 45
B-3078 Everberg
Belgium
VAT: BE - 0468.807.829
Office Phone: 0032 (0) 2 758 9962
- [cgal-discuss] convex polyhedron from planar halfspaces using double coordinates?, Maarten Moesen, 09/25/2017
