- To:
- Subject: [cgal-discuss] What does negative CGAL::Polygon_mesh_processing::volume mean?
- Date: Wed, 27 Sep 2017 02:16:45 -0700 (MST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:ZcFrPxZvtp4mPzuhnS/pw53/LSx+4OfEezUN459isYplN5qZpsqybnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i762xdJRES6bFI9Zr+tQs+Bx/iwguu98pmWbwRTjyemeptzKg+3pEPfrJo4m4xnf4c40RzPpzMcYv1KwmdlI1+7kBP158P295lmpXcD88k9/tJNBPypN58zSqZVWW9+a20=
What does negative CGAL::Polygon_mesh_processing::volume, of a triangular
mesh, say about the mesh?
- [cgal-discuss] What does negative CGAL::Polygon_mesh_processing::volume mean?, Iasonm, 09/27/2017
- Re: [cgal-discuss] What does negative CGAL::Polygon_mesh_processing::volume mean?, Iasonm, 09/27/2017
- Re: [cgal-discuss] What does negative CGAL::Polygon_mesh_processing::volume mean?, Pádraig Ó Conbhuí, 09/27/2017
