- To:
- Subject: [cgal-discuss] Problem installing CGAL on Ubuntu
- Date: Thu, 5 Oct 2017 07:24:49 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:3XxBBh3MRD1CgmH7smDT+DRfVm0co7zxezQtwd8ZsesTKPad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tLw6annrn5jEbHlDzNBF+O//uMo/UlcW+ke6oqLPJZAAdiz68brpoMF3iogHQucAMnaNtL68wzl3CpX4eKLce/n9hOV/Gx0W03cy35pM2qyk=
Hi there! I'm having issues installing the library CGAL, in details it have
success in all but for CGAL_QT5, here the output:
== Setting paths ==
-- Build CGAL from release in directory CGAL-4.11
-- Packagenames: CGAL-4.11
== Setting paths (DONE) ==
== Generate version files ==
-- CGAL_MAJOR_VERSION=4
-- CGAL_MINOR_VERSION=11
-- CGAL_BUGFIX_VERSION=0
-- CGAL_SONAME_VERSION=13
-- CGAL_SOVERSION =13.0.1
-- CGAL_REFERENCE_CACHE_DIR=
-- Building shared libraries
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- USING CMake version: 2.8.12
-- System: Linux
-- USING GCC_VERSION = '4.8.4'
-- Using gcc version 4 or later. Adding -frounding-math
== Generate version files (DONE) ==
== Set up flags ==
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING LDFLAGS = ' '
== Set up flags (DONE) ==
== Detect external libraries ==
-- External libraries supported:
GMP;GMPXX;MPFR;ZLIB;OpenGL;LEDA;MPFI;RS;RS3;OpenNL;Eigen3;BLAS;LAPACK;QGLViewer;ESBTL;Coin3D;NTL;IPE
-- Preconfiguring library: GMP ...
-- GMP has been preconfigured:
-- UseGMP-file:
-- GMP include: /usr/include/x86_64-linux-gnu
-- GMP libraries: /usr/lib/x86_64-linux-gnu/libgmp.so
-- GMP definitions:
-- USING GMP_VERSION = '5.1.3'
-- Preconfiguring library: MPFR ...
-- MPFR has been preconfigured:
-- UseMPFR-file:
-- MPFR include: /usr/include
-- MPFR libraries: /usr/lib/x86_64-linux-gnu/libmpfr.so
-- MPFR definitions:
-- USING MPFR_VERSION = '3.1.2'
-- __cplusplus is 199711
-- Boost version: 1.54.0
-- Found the following Boost libraries:
-- thread
-- system
-- Boost include: /usr/include
-- Boost libraries:
/usr/lib/x86_64-linux-gnu/libboost_thread.so;/usr/lib/x86_64-linux-gnu/libboost_system.so;/usr/lib/x86_64-linux-gnu/libpthread.so
-- Boost definitions:
-- USING BOOST_VERSION = '1.54.0'
== Detect external libraries (DONE) ==
== Write compiler_config.h ==
-- Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
-- Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Success
-- Performing Test CGAL_CFG_IEEE_754_BUG - Success
-- Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_6 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_7 - Success
-- Performing Test CGAL_CFG_MATCHING_BUG_8 - Success
-- Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Success
-- Performing Test CGAL_CFG_NO_LIMITS - Success
-- Performing Test CGAL_CFG_NO_NEXTAFTER - Success
-- Performing Test CGAL_CFG_NO_STL - Success
-- Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
-- Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
-- Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success
-- Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success
-- Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
== Write compiler_config.h (DONE) ==
== Generating build files ==
Configuring libCGAL
-- Requested component: MPFR
-- Requested component: GMP
libCGAL is configured
-- Sources for CGAL component library 'CGAL_Core' detected
Configuring libCGAL_Core
-- thread
-- system
libCGAL_Core is configured
-- Sources for CGAL component library 'CGAL_ImageIO' detected
Configuring libCGAL_ImageIO
-- USING ZLIB_VERSION = '1.2.8'
libCGAL_ImageIO is configured
-- Sources for CGAL component library 'CGAL_Qt5' detected
Configuring libCGAL_Qt5
-- libCGAL_Qt5 is missing the dependencies: Qt5OpenGL Qt5Svg Qt5 cannot be
configured.
-- Sources for CGAL component libraries 'CGAL_Core;CGAL_ImageIO;CGAL_Qt5'
detected
Anything I could do to make it work? Since it doesnt work with CGAL_Qt5 I'm
not able to run any demo, I've already tried looking for similar topics, but
couldnt find a way to make it work.
Any Help?
- [cgal-discuss] Problem installing CGAL on Ubuntu, gligart, 10/05/2017
- Re: [cgal-discuss] Problem installing CGAL on Ubuntu, Laurent Rineau (CGAL/GeometryFactory), 10/05/2017
- Re: [cgal-discuss] Problem installing CGAL on Ubuntu, gligart, 10/09/2017
- Re: [cgal-discuss] Problem installing CGAL on Ubuntu, Laurent Rineau (CGAL/GeometryFactory), 10/11/2017
- Re: [cgal-discuss] Problem installing CGAL on Ubuntu, Christophe Riedinger, 10/19/2017
- Re: [cgal-discuss] Problem installing CGAL on Ubuntu, gligart, 10/20/2017
- Re: [cgal-discuss] Problem installing CGAL on Ubuntu, Marc Glisse, 10/05/2017
