cgal-discuss - Re: [cgal-discuss] Problem installing CGAL on Ubuntu
  • To:
  • Subject: Re: [cgal-discuss] Problem installing CGAL on Ubuntu
  • Date: Thu, 5 Oct 2017 20:05:40 +0200 (CEST)
On Thu, 5 Oct 2017, gligart wrote:
Hi there! I'm having issues installing the library CGAL, in details it have
success in all but for CGAL_QT5, here the output:
Anything I could do to make it work? Since it doesnt work with CGAL_Qt5 I'm
not able to run any demo, I've already tried looking for similar topics, but
couldnt find a way to make it work.
Hello,
CGAL is packaged in Ubuntu. Even if you are not going to use that package (for instance you want a more recent version), the package still contains useful information.
apt build-dep cgal
will install the packages that must be installed to build the Ubuntu cgal package (may require sudo, etc).
apt show libcgal-demo
look at the Suggests: field, the packages listed there are all relevant to some demos.
The newer version of CGAL may have new requirements, but not very often unless you are using an ancient version of Ubuntu, and the old requirements are still a good starting point.
Marc Glisse
