cgal-discuss - [cgal-discuss] Problems with CGAL::poisson_surface_reconstruction_delaunay
  • To:
  • Subject: [cgal-discuss] Problems with CGAL::poisson_surface_reconstruction_delaunay
  • Date: Fri, 3 Nov 2017 16:59:23 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Dkim-filter: OpenDKIM Filter v2.11.0 mailrelay.tugraz.at 3yT68X2sB0z1LXtF
  • Ironport-phdr: 9a23:eXCZURNpPiq+7UGeG7Ul6mtUPXoX/o7sNwtQ0KIMzox0K/T7rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6alEW19iIcGwWmfUorfqWmUrLV2s+43uT395zIaBhTnxK8Z6lzJVO4t1b/rM4T1LdiLaM40VPppX9afu1Qwys8JVWXjRP14MGY/ZVstThNtOgo5YhJTfOpLOwDUbVEAWF+YCgO78rxuEydFQY=
Hi,
the function poisson_surface_reconstruction_delaunay very frequently crashes on my datasets.
I use standard parameters (I also tried varying the parameters) and I compute the average spacing with CGAL::compute_average_spacing. I also remove outliers with CGAL::remove_outliers.
On two of my datasets I regularly (at least at 2 out of 3 runs) get this error:
CGAL ERROR: assertion violation! File: CGAL-4.11/include/CGAL/Surface_mesher/Surface_mesher.h Line: 253 Explanation: (56.0006 41.2038 -0.0783118) is already inserted on surface.
After asking google, I found out that setting the Non_manifold_tag() might help. But this didn't help in my case. Then I usually get other errors:
CGAL::Polyhedron_incremental_builder_3<HDS>::
add_vertex_to_facet(): input error: disconnected facet complexes at vertex 225:
           involved facets are: 137 134 135 (closed cycle) and.
or this one:
lookup_halfedge(): input error: facet 1803 shares a halfedge from vertex 3005 to vertex 3004 with facet 1788.
Can someone give me a hint what the problem could be? My input point cloud has several big holes. Might that be a problem?
Thanks!
Thomas
Dipl.-Ing. Thomas Holzmann
TU Graz - Institut fuer Maschinelles Sehen und Darstellen
Graz University of Technology - Institute for Computer Graphics & Vision
Inffeldgasse 16/II, 8010 Graz, Austria
http://www.icg.tugraz.at/
phone: +43 316 873 5091
