cgal-discuss - Re: [cgal-discuss] Problems with CGAL::poisson_surface_reconstruction_delaunay
  • To:
  • Subject: Re: [cgal-discuss] Problems with CGAL::poisson_surface_reconstruction_delaunay
  • Date: Mon, 6 Nov 2017 10:06:20 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:seJTjh1dHfGMly3LsmDT+DRfVm0co7zxezQtwd8ZsesRLPad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tLw6annrn5jEbHlDzNBF+O//uMo/UlcW+ke6oqLPJZAAdvzu4ZrU6AxSspBjdsdVe1ZBjL6E3jBTIuHJVd+NK7WxlIleegwzt6M674Jl54mJbvPd3pJ0IarnzY6ltFe8QNz8hKW1gvMA=
Le 03/11/2017 à 16:59, Thomas Holzmann a écrit :
Hi,
the function poisson_surface_reconstruction_delaunay very frequently crashes on my datasets.
I use standard parameters (I also tried varying the parameters) and I compute the average spacing with CGAL::compute_average_spacing. I also remove outliers with CGAL::remove_outliers.
On two of my datasets I regularly (at least at 2 out of 3 runs) get this error:
CGAL ERROR: assertion violation! File: CGAL-4.11/include/CGAL/Surface_mesher/Surface_mesher.h Line: 253 Explanation: (56.0006 41.2038 -0.0783118) is already inserted on surface.
After asking google, I found out that setting the Non_manifold_tag() might help. But this didn't help in my case. Then I usually get other errors:
CGAL::Polyhedron_incremental_builder_3<HDS>::
add_vertex_to_facet(): input error: disconnected facet complexes at vertex 225:
           involved facets are: 137 134 135 (closed cycle) and.
or this one:
lookup_halfedge(): input error: facet 1803 shares a halfedge from vertex 3005 to vertex 3004 with facet 1788.
Can someone give me a hint what the problem could be? My input point cloud has several big holes. Might that be a problem?
Thanks!
Hello,
It seems that the surface mesher does not manage to mesh the implicit function at the required precision. Have you tried to increase the spacing parameter or the sm_distance parameter?
The holes should not be a problem in theory as long as the inferred surface is closed. Poisson cannot work properly if the inferred surface is not closed (if it is not surrounding a volume with a well-defined interior and exterior). Badly defined or badly oriented normal vectors can also lead to problems.
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
