cgal-discuss - [cgal-discuss] Apply rgb image to a surface mesh.
  • To:
  • Subject: [cgal-discuss] Apply rgb image to a surface mesh.
  • Date: Fri, 17 Nov 2017 05:15:37 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23:4hgAHx+hYrmhKP9uRHKM819IXTAuvvDOBiVQ1KB+1OocTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47ITgaM8zjrtXZSQU2ndFk9GuOgEYHbi4G71vu55obISwROnju0J71ofzusqgCEstQdiKUqfqIswRLHo3xSerQJ7WxtLFOX2R3745Hjr9ZY7y1Mtqd4pIZ7WqLgcvFjFeRV
Hello,
I am new to CGAL. I acquired a point cloud and an rgb .png image of my face
via Kinect 2. I managed to obtain a surface mesh from the point cloud as in
the Poisson_surface_reconstruction_3/poisson_reconstruction_example.cpp
example. After some processing I obtained a mesh similar to the
"nefertiti.off" used in the
Surface_mesh_parameterization/simple_parameterization.cpp example, which is
not "closed" in the back.
Now I would like to apply the image to this mesh (in order to take snapshots
of the rendering from different angles), however I don't know how can I do
such thing.
Thank you in advance
Luca
  • [cgal-discuss] Apply rgb image to a surface mesh., lucaF, 11/17/2017
