cgal-discuss - Re: [cgal-discuss] error: ‘exact’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation
  • To:
  • Subject: Re: [cgal-discuss] error: ‘exact’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation
  • Date: Fri, 17 Nov 2017 05:29:33 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23:JlEU1R967IPLGv9uRHKM819IXTAuvvDOBiVQ1KB+1ugcTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS46tL2HV93a95DpXFhTkPhduPcz0HJTThoK5zbOc4ZrWNiRBnz27ZPsmNQyqqgHcsMQ+jo5rK6J3wRzM9CgbM99KzH9lcArA1y334d29qcZu
The error is triggered when I call
CGAL::extract_mean_curvature_flow_skeleton(M,s);
where M is a
CGAL::Surface_mesh<CGAL::Exact_predicates_inexact_constructions_kernel::Point>
The full error is:
/usr/local/include/CGAL/Polygon_mesh_processing/measure.h:450: required
from ‘typename CGAL::GetGeomTraits<TriangleMesh,
CGAL::pmp_bgl_named_params&lt;T, Tag, Base> >::type::FT
CGAL::Polygon_mesh_processing::area(const TriangleMesh&, const
CGAL::pmp_bgl_named_params<T, Tag, Base>&) [with TriangleMesh =
CGAL::Polyhedron_3<CGAL::Epick,
CGAL::internal::Skel_polyhedron_items_3&lt;CGAL::SM_Vertex_index>,
CGAL::HalfedgeDS_default, std::allocator<int> >; T = CGAL::Epick; Tag =
CGAL::internal_np::geom_traits_t; Base =
CGAL::pmp_bgl_named_params<CGAL::internal::Point_accessor&lt;CGAL::internal::In_place_list_iterator&lt;CGAL::HalfedgeDS_in_place_list_vertex&lt;CGAL::I_Polyhedron_vertex&lt;CGAL::internal::Skel_HDS_vertex_type&lt;CGAL::HalfedgeDS_list_types&lt;CGAL::Epick,
CGAL::I_Polyhedron_derived_items_3&lt;CGAL::internal::Skel_polyhedron_items_3&lt;CGAL::SM_Vertex_index>
>, std::allocator<int> >, CGAL::Point_3<CGAL::Epick>, long unsigned int,
CGAL::SM_Vertex_index> > >,
std::allocator<CGAL::HalfedgeDS_in_place_list_vertex&lt;CGAL::I_Polyhedron_vertex&lt;CGAL::internal::Skel_HDS_vertex_type&lt;CGAL::HalfedgeDS_list_types&lt;CGAL::Epick,
CGAL::SM_Vertex_index> > > > >, CGAL::Point_3<CGAL::Epick>,
CGAL::Point_3<CGAL::Epick>&>, CGAL::internal_np::vertex_point_t,
boost::no_property>; typename CGAL::GetGeomTraits<TriangleMesh,
CGAL::pmp_bgl_named_params&lt;T, Tag, Base> >::type::FT = double]’
This is triggered because
