Re: [cgal-discuss] How to Iterate over each face in DT3 and the get the vertices?
- To:
- Subject: Re: [cgal-discuss] How to Iterate over each face in DT3 and the get the vertices?
- Date: Fri, 17 Nov 2017 13:40:58 -0700 (MST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=Pass
- Ironport-phdr: 9a23:IrEHfxJS/EUf7+rM09mcpTZWNBhigK39O0sv0rFitYgXLfzxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uDUdExG6OQtuLfnuAabTid623qa84c79eQJN0QGwZ69yLRH+hgzcrcAMyd9ZJ6AtyhrN5ENBf+1QxH1lIQrLxj7h48328ZJ+pXcD88k9/tJNBP2pN58zSqZVWWwr
Thank you so much . This helped me . I was able to understand 3D better,
after looking at 2D edge Iteration
eit->first->vertex(Triangulation::ccw(eit->second))->point()
eit->first->vertex(Triangulation::cw(eit->second))->point()
Senthil Caesar
- [cgal-discuss] How to Iterate over each face in DT3 and the get the vertices?, Senthil Caesar, 11/16/2017
- Re: [cgal-discuss] How to Iterate over each face in DT3 and the get the vertices?, MaelRL, 11/17/2017
- Re: [cgal-discuss] How to Iterate over each face in DT3 and the get the vertices?, Senthil Caesar, 11/17/2017
