cgal-discuss - [cgal-discuss] Corefinement and Boolean Operations and original face index
  • To:
  • Subject: [cgal-discuss] Corefinement and Boolean Operations and original face index
  • Date: Mon, 4 Dec 2017 10:12:39 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:zEzHLRLkadhS43Ch69mcpTZWNBhigK39O0sv0rFitYgXLfjxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uDUdExG6OQtuLfnuAabTid623qa84c79eQJN0Ri6aLhyLRD+lQLMusQMhpZyYvIzzRLConpNPfxR2G9lP1WOjz7/59uv9YRutS9XvqRypIZ7TazmcvFgHvRjBzM8PjVt6Q==
Hello,
I am trying to evaluate the new CGAL feature that allows to efficiently intersect two polygonal
meshes (CGAL::Polygon_mesh_processing::corefine_and_compute_intersection).
In my context, it is important to be able to track down from which initial input mesh face
a face in the triangulated mesh output comes from. It looks like this is where the named property
called "face_patch_map" could have been useful. However, if I am correct, this feature is not
supported by the algorithm. Am I wrong?
Is there another (topological) way I could reconstruct those face ids?
Thanks for your help,
Best,
Joachim
Joachim Pouderoux, PhD
Technical Expert - Scientific Computing Team
Kitware SAS
