- To:
- Subject: Re: [cgal-discuss] Corefinement and Boolean Operations and original face index
- Date: Mon, 4 Dec 2017 15:37:40 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:O4+38hG/KmS8mgZirGqiBZ1GYnF86YWxBRYc798ds5kLTJ76rsSwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWExGVNQVCnaUI1e7y0ScbuiJG82Om2vpHSeA5VnyGVYLVoLRzwox+CmNMRhN4oEas7wwDVo3ZOM8BR32JvORrTsBv748qs5o9N+i9MvOgwtoQIBb7+eL45SqAeCTAOPGU85cmtvh7GG1jcrkAAW3kbx0IbSzPO6wv3C8qpvw==
This is something that we use to have in a previous undocumented version
but it was not completely ported in the last version. I don't think
a lot of work is needed and I could add it if there is enough interest
for this feature.
Right now, I don't think there is any clean workaround.
Sebastien.
On 12/04/2017 03:12 PM, Joachim Pouderoux wrote:
Hello,
I am trying to evaluate the new CGAL feature that allows to efficiently intersect two polygonal
meshes (CGAL::Polygon_mesh_processing::corefine_and_compute_intersection).
In my context, it is important to be able to track down from which initial input mesh face
a face in the triangulated mesh output comes from. It looks like this is where the named property
called "face_patch_map" could have been useful. However, if I am correct, this feature is not
supported by the algorithm. Am I wrong?
Is there another (topological) way I could reconstruct those face ids?
Thanks for your help,
Best,
Joachim
*Joachim Pouderoux*, PhD
/Technical Expert - Scientific Computing Team/
*Kitware SAS <http://www.kitware.fr>*
- [cgal-discuss] Corefinement and Boolean Operations and original face index, Joachim Pouderoux, 12/04/2017
- Re: [cgal-discuss] Corefinement and Boolean Operations and original face index, Sebastien Loriot (GeometryFactory), 12/04/2017
