- To:
- Subject: Re: [cgal-discuss] About Medial Axis Transform contributing
- Date: Wed, 17 Jan 2018 21:22:12 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I'll answer shortly, but I think that someone closer to the topic should be involved.
At first glance I don't see a reason why this cannot be added to CGAL, but perhaps one of you guys do. ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On 16 January 2018 at 15:09, Jia Bill <> wrote:
I'm working on Q-MAT which stands for computing Medial Axis Transform (MAT) by Quadratic Error Minimization, an efficient way to calculate MAT. For detail, check here: http://cgcad.thss.tsinghua.edu.cn/wangbin/qmat/qmat.html
Is this valuable and effective enough to contribute it into the CGAL repo. Also does it break the design goals if I use some of the algorithms already in the CGAL?
I'm really new in contributing to such a well-known repo, so all suggestions are welcomed, especially about what I should do next.
发自网易邮箱大师
- [cgal-discuss] About Medial Axis Transform contributing, Jia Bill, 01/16/2018
- Re: [cgal-discuss] About Medial Axis Transform contributing, Efi Fogel, 01/17/2018
