- To:
- Subject: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?
- Date: Thu, 18 Jan 2018 11:23:40 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Dear all,
in principle, all I need is provided in the example (Triangulation_3/info_insert_with_pair_iterator.cpp), but to speed up my project I want to use a parallel form of it. "Triangulation_3/parallel_insertion_in_delaunay_3.ccp" seems to provide all pieces. However I cannot get the hang on how to merge these two examples.- [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, Thierry Fredrich, 01/18/2018
- Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, Sebastien Loriot (GeometryFactory), 01/18/2018
- Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, Thierry Fredrich, 01/18/2018
- Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, MaelRL, 01/18/2018
- Re: [cgal-discuss] info_insert_with_pair_iterator.cpp in parallel form?, Biswajit Biswas, 01/18/2018
