- To:
- Subject: Re: [cgal-discuss] Triangulated Surface Mesh Skeletonization compile errors
- Date: Mon, 22 Jan 2018 03:07:20 -0700 (MST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:4jBSzBKR3jfSPBzrTNmcpTZWNBhigK39O0sv0rFitYgRL/XxwZ3uMQTl6Ol3ixeRBMOHs6sC07KempujcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47xaFLIv3K98yMZFAnhOgppPOT1HZPZg9iq2+yo9JDffxhEiCChbb9uMR67sRjfus4KjIV4N60/0AHJonxGe+RXwWNnO1eelAvi68mz4ZBu7T1et+ou+MBcX6r6eb84TaFDAzQ9L281/szrugLdQgaJ+3ART38ZkhtMAwjC8RH6QpL8uTb0u+ZhxCWXO9D9QLYpUjqg8qhrUgflhikHOTAn82/YiMJwgr9Urx29qBJy2JLUbYOJOPZiYq/RYc0WSGxcVchRTSxBBYa8YpMKD+UbIeZYr5TyqEUTpha5AgmsAP3gyzBLhn/xx6061eUhEAHY0wwmHNIOt2/ZrNrwNKgIUOC1yLPEwinEb/NTwDrw7pXDfB4mofGJR71wcMzRxFEpFwzflVqfsojlMC2P2usRtGib6vJsVf6yi28opQF+uD2vxsYoiojJnI4VzUrE9Sp/zY0oJtO4UFZ2bcOlHZdOrS2WKYt7T804T211tis3xKcKtJylcCUM1Z8p3QTQa+adfIiN+h/jVPieITN/hH99frKyiAy+8U66xeLnTca01EhFojBZndnLs3ABzx3T6s6ZRfth5kqtxDeC2x7J5u1aIU05m7DXJ4Mvz7M+jJYes1rPEjfzmErsja+Wcksk+vKv6+TierjmoZucOJF7iwH9NaQugMq/AeU4MwcQWWib+uO82abs/U38WrpKj/k2nrPFv5DdIMQXvrS5DBNN0oY/9xa/CC+r38gXnXYdKFJJYQ+Ij4nyO17SPfD4Fuy/jk+3kDZrwvDGJqfuDo/MLnjFirfhfKxy51RSyAopnphj4MdfBbgFZf7yQUTsr8fwDxkjMgXyzfy0Js9609YbUH6PDqLRZKTWvE+L4fgpIviBYowSkDn4IvkhofXpiClqyhcmYaC10M5POziDFfN8LhDBOCu+spI6CW4P+zEGYqnvgVyGXyRUYi/rDa057zA/TomhCNWYH9z/sPm6xC6+W6ZuSCVeEFnVSCXncoyFX7EHbyfAepY8wAxBbqCoTsoa7T/rtAL+zOM6fOyIvCsRv5jn2Z5+4OiBzBw=
Hi Sebastien,
Thank you for answer; I thought about EIGEN already.
As I add it on Stackoverflow:
Last thing I tried was EIGEN installation (as possible solution of
CGAL_EIGEN3_ENABLED correct usage). I loaded the package as pointed by CGAL
guide (http://eigen.tuxfamily.org) and tried to create project with Cmake.
But I got a number of errors about missing BLAS; I looked for it, but find
only LAPACKE which exist only in 32 bits version and needs also Fortrane
compiler. The most bad here is I don't be sure I go to the right way.
Maybe you give me idea what I do wrongly; my C++ is not so deep to solve
this.
Thanks, Oleksandr
- [cgal-discuss] Triangulated Surface Mesh Skeletonization compile errors, mathde, 01/19/2018
- Re: [cgal-discuss] Triangulated Surface Mesh Skeletonization compile errors, Sebastien Loriot (GeometryFactory), 01/22/2018
- Re: [cgal-discuss] Triangulated Surface Mesh Skeletonization compile errors, mathde, 01/22/2018
- Re: [cgal-discuss] Triangulated Surface Mesh Skeletonization compile errors, mathde, 01/23/2018
