cgal-discuss - Re: [cgal-discuss] Triangulated Surface Mesh Skeletonization compile errors
  • To:
  • Subject: Re: [cgal-discuss] Triangulated Surface Mesh Skeletonization compile errors
  • Date: Tue, 23 Jan 2018 03:18:32 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
*The question is solved!*
The answer was extremely simple (please note I'm new in C++):
1. I loaded and unzip EIGEN (it need not to install); for convenience I
create also EIGEN_DIR variable;
2. I added to Additional Include Directories: $(EIGEN_DIR);
3. I added before #include statements #define CGAL_EIGEN3_ENABLED;
4. I added to Additional Dependencies such libs:
$(CGAL_ROOT)\auxiliary\gmp\lib\libmpfr-4.lib
$(CGAL_ROOT)\auxiliary\gmp\lib\libgmp-10.lib
and it start to work!
Thanks, Oleksandr
