cgal-discuss - [cgal-discuss] Hausdorff distance - bad alloc
  • To:
  • Subject: [cgal-discuss] Hausdorff distance - bad alloc
  • Date: Fri, 9 Feb 2018 08:54:48 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hello!
I am trying to use approximate_Hausdorff_distance on CGAL::Surface_mesh_3
data structure meshes, but after +- 30 seconds of calculations i'm getting
every time bad alloc .
Code was taken from PMP example:
std::cout << "Approximated Hausdorff distance: "
<< CGAL::Polygon_mesh_processing::approximate_Hausdorff_distance
<TAG>(mesh1, mesh2,
CGAL::Polygon_mesh_processing::parameters::number_of_points_per_area_unit(4000))
<< std::endl;
